IOC on 18F2580?
+ Reply to Thread
Results 1 to 3 of 3
Thread: IOC on 18F2580?
    Default Re: IOC on 18F2580?
    Does this mean that I cannot use an interrupt for this task on this MCU?
    why not use one of the interrupt pins int0 int1 int2
    alternatively
    portb pins 4 to 7 have interrupt on change capability
    read data sheet interrupt section and i/o port sections chapters 9 and 10
    Jul 2024
    Greetings Richard,
    you are correct. I can use RBC interrupt.
    The only limitation is that, between RB4 and RB7, the pins that will trigger the interrupt are the ones set as inputs.
    If I only want one pin, I need to set the others as outputs.
    Thank you so much for your help.
    Best regards
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 21:11
  2. IOC on the 27k40
    By longpole001 in forum PBP3
    Last Post: - 10th December 2019, 13:28
  3. IOC question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 19:21
  4. McLoader and 18F2580
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 12th February 2007, 06:20
Members who have read this thread : 6
