IOC on 18F2580?
Results 1 to 3 of 3
Thread: IOC on 18F2580?
    Jul 2024
    Default IOC on 18F2580?
    Hi guys,
    I'm trying to figure out how to trigger a routine when a especific pin changes from digital low to high.
    I can eventually create a jump to a short check on that pin and then return to the main program but my first though was to use an interrupt and leave the check task to it.
    Interrupt on change (IOC) was my first guess but checking the 18F2580 datasheet I cannot find any IOC register.
    Does this mean that I cannot use an interrupt for this task on this MCU?
    Default Re: IOC on 18F2580?
    why not use one of the interrupt pins int0 int1 int2
    alternatively
    portb pins 4 to 7 have interrupt on change capability
    read data sheet interrupt section and i/o port sections chapters 9 and 10
    Jul 2024
    Greetings Richard,
    you are correct. I can use RBC interrupt.
    The only limitation is that, between RB4 and RB7, the pins that will trigger the interrupt are the ones set as inputs.
    If I only want one pin, I need to set the others as outputs.
    Thank you so much for your help.
    Best regards
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 21:11
  2. IOC on the 27k40
    By longpole001 in forum PBP3
    Last Post: - 10th December 2019, 13:28
  3. IOC question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 19:21
  4. McLoader and 18F2580
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 12th February 2007, 06:20
