How do you chose ADCIN channel in this case
Results 1 to 5 of 5
    Default Re: How do you chose ADCIN channel in this case
    Note to the next guy:
    You don't need the register if there's only the ADC channel inside it (I keep the list only as documentation for the channel numbers).
    'ADPCH = %00000000                   ' ADC POSITIVE CHANNEL SELECTION REGISTER
    '   bit 7-6 Unimplemented: Read as ‘0’
    '   bit 5-0 ADPCH<5:0>: ADC Positive Input Channel Selection bits
    '               111111 = Fixed Voltage Reference (FVR)
    '               111110 = DAC1 output
    '               111101 = Temperature Indicator
    '               111100 = AVSS (Analog Ground)
    '               111011 = Reserved. No channel connected.
    '               100010 = ANE2       * 16F18877 only
    '               100001 = ANE1       * 16F18877 only
    '               100000 = ANE0       * 16F18877 only
    '               011111 = AND7       * 16F18877 only
    '               011110 = AND6       * 16F18877 only
    '               011101 = AND5       * 16F18877 only
    '               011100 = AND4       * 16F18877 only
    '               011011 = AND3       * 16F18877 only
    '     26 --->   011010 = AND2       * 16F18877 only
    '     25 --->   011001 = AND1       * 16F18877 only
    '               011000 = AND0       * 16F18877 only
    '               010111 = ANC7
    '               010110 = ANC6
    '               010101 = ANC5
    '               010100 = ANC4
    '               010011 = ANC3
    '               010010 = ANC2
    '               010001 = ANC1
    '               010000 = ANC0
    '               001111 = ANB7
    '               001110 = ANB6
    '               001101 = ANB5
    '               001100 = ANB4
    '               001011 = ANB3
    '               001010 = ANB2
    '               001001 = ANB1
    '               001000 = ANB0
    '               000111 = ANA7
    '               000110 = ANA6
    '               000101 = ANA5
    '               000100 = ANA4
    '               000011 = ANA3
    '               000010 = ANA2
    '               000001 = ANA1
    '               000000 = ANA0
    You only need to declare the channel in the ADCIN command:
            ADCIN 26, ADCinput
    I think this was always the case with the integrated ADCIN command of the PBP.
    Then you can always mess with the registers if your are brave enough!
  1. Best way to shut down HPWM channel?
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 26th January 2010, 23:01
  2. 16-Channel LED Drivers
    By Sponge Bob in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 05:48
  3. Multiplexer channel selection
    By Castor in forum mel PIC BASIC Pro
    Last Post: - 19th May 2008, 11:51
  4. I need Help to Connect P-Channel Mosfet
    By jetpr in forum Schematics
    Last Post: - 6th February 2006, 13:06
  5. 16F819 ADCIN Channel Select?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 19:31
