Framing error if I disable transmitter after shift register is empty?
Results 1 to 40 of 46
    Default Re: Framing error if I disable transmitter after shift register is empty?
    The USART section in the datasheet for your device will tell you if you should set/clear the TRIS bits for the TX/RX pins....
    I've misunderstood/misinterpreted the data sheet before. Seriously, I read the EUSART section and my eyes gloss over when they start making distinctions between half-duplex, full-duplex, synchronous, asynchronous...)
    ..If the chip supports open-drain mode then you just need to setup the TX pin to enable it at startup (ODCONC.6 = 1).
    There's no need to set and clear it, and you won't need to enable/disable TXEN anymore either...
    Something like..?
    TRISC.7=1
    ODCONC.6 = 1
    Loop:
    TX, RX, rinse repeat
    I would have thought you need to reset ODCONC.6 to "standard push/pull"...? (Possible example of not always understanding what the datasheet "means").
    ...If your pic has PPS you'll probably need to set that up too to assign the pin to the UART TXD function.
    PPS output functions aren't typically enabled by default.
    Yes, I figured that much. There's just so many peripherals available (coming from a guy that started with a 16F628).
    EDIT: I just rechecked the EUSART section (starts at page 543), and they never mention ODCON (last occurence is at page 233).
    The datasheet says very little about ODCON:
    An open-drain or open-collector output pin is driven by a single transistor, which pulls the pin to only one voltage (generally, to ground). When the output device is off, the pin is left floating (open, or hi-z). A common example is an n-channel transistor which pulls the signal to ground when the transistor is on or leaves it open when the transistor is off.
    Open-drain refers to such a circuit implemented in FET technologies because the transistor’s drain terminal is connected to the output; open-collector means a bipolar transistor’s collector is performing the function.
    When the Open-drain transistor is off, the signal line is free to be driven low by another device, it generally will be pulled up by a resistor. The resistor prevents an undefined, floating state.
  1. Trying to emulate shift register
    By RuudNL in forum General
    Last Post: - 17th March 2013, 20:57
  2. pic+shift register+lcd
    By eworld in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2012, 06:11
  3. Long shift register
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 18th April 2009, 20:14
  4. Framing Error /w USART
    Last Post: - 27th February 2007, 02:34
  5. Replies: 15
    Last Post: - 30th January 2005, 04:58
