Framing error if I disable transmitter after shift register is empty? - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 46 of 46
  1. #41
    Default Re: Framing error if I disable transmitter after shift register is empty?
    (I remember reading somewhere that USART ignores TRIS, or something...?)
    you may well have but if you think every pic chip is the same then you will be in for a world of hurt . read the data sheet
    I don't have carpet, and that's the extent of my ESD protections.
    Well the carpet is one thing. Even if you just walked the room and returned back to you chair (even worse if it has suspension), then you may well have charged enough to destroy the chips.
    You have to remember to ground yourself just before you touch components or even better have a wrist band to permantly ground your body (through a high value resistor of course).
    ESD can destroy just a tiny part of the chip, enough to drive you crazy!
    Aug 2011
    Am I supposed to set TRIS as well?
    The USART section in the datasheet for your device will tell you if you should set/clear the TRIS bits for the TX/RX pins.
    If the chip supports open-drain mode then you just need to setup the TX pin to enable it at startup (ODCONC.6 = 1).
    There's no need to set and clear it, and you won't need to enable/disable TXEN anymore either.
    Add a pullup to the TX line (you say you already have one), and you can connect all the TX lines from the different pics together now.
    If your pic has PPS you'll probably need to set that up too to assign the pin to the UART TXD function.
    PPS output functions aren't typically enabled by default.
  4. #44
    not really , why would you want to change it back and forth?...
    To be able to add more PICs later on the TX line.
    ...is there a pullup for the tx line ?...
    Yup, on RX also. Both are on PIC #1.
    (Using 16F18877 for testing)
    PIC #1:
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    include "DT_INTS-14_16F18877.bas"
    include "ReEnterPBP.bas"
            INT_Handler    RX_INT,  _RXInterrupt,   PBP,  yes
        INT_CREATE                  ; Creates the interrupt processor
        INT_ENABLE    RX_INT        ; Enables RX interrupts
    DEFINE OSC 32
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000000
    TRISD = %00000000
    TRISE = %00001000
    LEDblink            var LatB.5
    RecvData            var BYTE[11]
    UsartFlag           Var byte
        pause 200
        LEDblink = 0
        UsartFlag = 0
        goto Start
    RXInterrupt:
        hserin [ wait("["), STR RecvData\11\"]" ]
        UsartFlag = 1
    @ INT_RETURN
    Start:
    '    ODCONC.6 = 0
        hserout [   "[X]"   ]
        while TX1STA.1 = 0               ' Check TRMT bit
        wend
    '    ODCONC.6 = 1
    Mainloop:
        LEDblink = 1
        if UsartFlag = 0 then
            UsartFlag = 0
        LEDblink = 0
        goto Mainloop
    PIC #2:
            INT_Handler    RX_INT,  _ReceiveInterrupt,   PBP,  yes
    DEFINE OSC 32
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXBIT 6
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %10000000
    TRISD = %00000000
    TRISE = %00001000
    LEDblink            var LatD.0
    UsartFlag           Var byte
        pause 200
        LEDblink = 0
        UsartFlag = 0
        goto Start
    ReceiveInterrupt:
        UsartFlag = 1
    @ INT_RETURN
    Start:
    Mainloop:
        LEDblink = 1
        if UsartFlag = 1 then
    '        ODCONC.6 = 0
            hserout [   "[Y]"   ]
            wend
    '        ODCONC.6 = 1
            UsartFlag = 0
        LEDblink = 0
      GOTO Mainloop
    Results:
    Custom DT_INTS-14.bas (IOC, RX, CCPx):
    '*  Name    : DT_INTS-14_16F1885x-7x.bas                                   *
    '*  Author  : Darrel Taylor (modified by Demon)                            *
    '*  Version : 1.15 (8/29/2024)                                             *
    '*  Date    : OCT 13, 2009                                                 *
    '* REV 1.15  Customized for 16F1885xx-7x (IOC, USART-RX, CCPx)             *
    '* REV 1.10  Fixes Duplicate label error when Handlers cross page boundary *
    '*           Fixes error with 16F1's and MPLAB 8.53 (high)                 *
    '* REV 1.00  Completely re-written, with optimization and F1 chips in mind *
    '* REV 0.93  Fixed CMIF and EEIF problem with older PIC's                  *
    '*           that have the Flags in PIR1 instead of PIR2                   *
    '* Rev 0.92  solves a "Missed Interrupt" and                               *
    '*           banking switching problem                                     *
    DEFINE  DT_INTS_VERSION  110
    DEFINE  INTHAND  INT_ENTRY
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    fsave       VAR BYTE    BANK0   SYSTEM      ' location for FSR register
    RetAddr     VAR WORD    BANK0
    INT_Bits    VAR BYTE    BANK0
      Serviced  VAR INT_Bits.0
      Vars_Saved VAR INT_Bits.1
    GIE         VAR INTCON.7
    PEIE        VAR INTCON.6
      ifdef PM_USED                             ; verify MPASM is the assembler
        "ERROR: DT_INTS does not support the PM assembler, USE MPASM"
      ifdef ReEnterUsed
        ifdef ReEnterVersion
          if (ReEnterVersion < 34)
            error "Wrong version of ReEnterPBP.bas - Ver 3.4 or higher required
        if (BANK0_END == 0x7F)
          ifdef BANK1_END
            if (BANK1_END == 0xEF)   ; doesn't find 12F683
              variable ACCESSRAM = 1
              variable ACCESSRAM = 0
    #define OrChange Or change to   wsave BYTE $70 SYSTEM
    AddWsave macro B
      if (B == 0)
        if (ACCESSRAM == 1)
          error   "                     Add:"       wsave VAR BYTE $70 SYSTEM
          error   "                     Add:"       wsave VAR BYTE $20 SYSTEM
      if (B == 1)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave1 VAR BYTE $A0 SYSTEM, OrChange
      if (B == 2)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave2 VAR BYTE $120 SYSTEM, OrChange
      if (B == 3)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, OrChange
    #define WsaveE1(B) Chip has RAM in BANK#v(B), but wsave#v(B) was not found.
    ;#define WsaveE2(B) Uncomment wsave#v(B) in the DT_INTS-14.bas file.
    #define WsaveCouldBe This chip has access RAM at $70
    #define WsaveError(B) error  WsaveE1(B)
      ifndef FSR0L     ; not a 16F1
        ifndef wsave
    ;      if (ACCESSRAM == 1)
            error wsave variable not found,
            AddWsave(0)
            variable wsave = 0 ; stop further wsave errors
    ;      else
    ;      endif
          if (wsave == 0x70)
            if (ACCESSRAM == 0)
              error This chip does not have AccessRAM at $70, change to   wsave VAR BYTE $20 SYSTEM
              if (wsave != 0x20)
                error wsave must be either $20 or $70
        ifdef BANK1_START
          ifndef wsave1
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(1)
                AddWsave(1)
              if (ACCESSRAM == 1)
                if (wsave != 0x70)
                  WsaveCouldBe
        ifdef BANK2_START
          ifndef wsave2
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(2)
                AddWsave(2)
        ifdef BANK3_START
          ifndef wsave3
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(3)
                AddWsave(3)
    asm = 0
    Asm = 0
    ASM = 0
    pbp = 1
    Pbp = 1
    PBP = 1
    yes = 1
    Yes = 1
    YES = 1
    no  = 0
    No  = 0
    NO  = 0
    ;---[Original DEFINES]------------------------------------------------------
      #define ALL_INT      INTCON,GIE, INTCON,GIE      ;-- Global Interrupts   *
    ;  #define IOC_INT      INTCON,IOCIF, INTCON,IOCIE  ;-- Int On Change
    ;  #define RX_INT       PIR1,RCIF, PIE1,RCIE        ;-- USART Receive
    ;  #define CCP1_INT     PIR1,CCP1IF, PIE1,CCP1IE    ;-- CCP1
    ;  #define CCP2_INT     PIR2,CCP2IF, PIE2,CCP2IE    ;-- CCP2
    ;  #define CCP3_INT     PIR3,CCP3IF, PIE3,CCP3IE    ;-- CCP3
    ;  #define CCP4_INT     PIR3,CCP4IF, PIE3,CCP4IE    ;-- CCP4
    ;  #define CCP5_INT     PIR3,CCP5IF, PIE3,CCP5IE    ;-- CCP5
      #define IOC_INT      PIR0,IOCIF, PIE0,IOCIE      ;-- Int On Change       *
      #define RX_INT       PIR3,RCIF, PIE3,RCIE        ;-- USART Receive
      #define CCP1_INT     PIR6,CCP1IF, PIE6,CCP1IE    ;-- CCP1
      #define CCP2_INT     PIR6,CCP2IF, PIE6,CCP2IE    ;-- CCP2
      #define CCP3_INT     PIR6,CCP3IF, PIE6,CCP3IE    ;-- CCP3
      #define CCP4_INT     PIR6,CCP4IF, PIE6,CCP4IE    ;-- CCP4
      #define CCP5_INT     PIR6,CCP5IF, PIE6,CCP5IE    ;-- CCP5
    ;---[Returns the Address of a Label as a Word]------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
    ;    movlw High Label         ; get high byte  MPLAB 8.53 killed high
        movlw Label >> 8         ; get high byte
        movwf Wout + 1
    ;---[find correct bank for a BIT variable]----------------------------------
    CHKRP?T  macro reg, bit
        CHK?RP  reg
    ;---[This creates the main Interrupt Service Routine (ISR)]-----------------
    INT_CREATE  macro
      local OverCREATE
        L?GOTO OverCREATE
    INT_ENTRY
        ifndef FSR0L
          if (CODE_SIZE <= 2)
              movwf   wsave       ; 1 copy W to wsave register
              swapf   STATUS,W    ; 2 swap status reg to be saved into W
              clrf    STATUS      ; 3 change to bank 0
              movwf   ssave       ; 4 save status reg to a bank 0 register
              movf    PCLATH,W    ; 5 move PCLATH reg to be saved into W reg
              movwf   psave       ; 6 save PCLATH reg to a bank 0 register
          endIF
          movf      FSR,W         ; 7 move FSR reg to be saved into W reg
          movwf     fsave         ; 8 save FSR reg to a bank 0 register
          banksel 0               ; BANK 0 for F1 chips
        variable  PREV_BANK = 0
        MOVE?CT  0, _Vars_Saved
    List_Start
        ifdef LoopWhenServiced
          MOVE?CT  0, _Serviced   ; indicate nothing has been serviced
        INT_LIST                  ; Expand the users list of interrupt handlers
                                ; INT_LIST macro must be defined in main program
          BIT?GOTO  1, _Serviced, List_Start
        ifdef ReEnterUsed         ; if ReEnterPBP.bas was included
            CHKRP?T  _Vars_Saved
            btfss    _Vars_Saved  ; if PBP system vars have been saved
            goto     INT_EXIT
            L?GOTO   _RestorePBP  ; Restore PBP system Vars
    INT_EXIT
        ifndef FSR0L              ; if chip is not an F1 - restore context
          clrf    STATUS          ; BANK 0
          movf    fsave,W         ; Restore the FSR reg
          movwf   FSR
          movf    psave,w         ; Restore the PCLATH reg
          movwf   PCLATH
          swapf   ssave,w         ; Restore the STATUS reg
          movwf   STATUS
          swapf   wsave,f
          swapf   wsave,w         ; Restore W reg
        retfie                    ; Exit the interrupt routine
      LABEL?L OverCREATE
        bsf      INTCON, 6      ; Enable Peripheral interrupts
        bsf      INTCON, 7      ; Enable Global interrupts
    ;---[Add an Interrupt Source to the user's list of INT Handlers]------------
    #INT_HANDLER  macro  FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      list
        local AfterSave, AfterUserRoutine, NoInt
          ifdef FlagBit
            CHK?RP   EnableReg
            btfss    EnableReg, EnableBit        ; if the INT is enabled
            goto     NoInt
            CHK?RP   FlagReg
            btfss    FlagReg, FlagBit            ; and the Flag set?
            goto     NoInt
              MOVE?CT  1, _Serviced
            if (Type == PBP)                     ; If INT handler is PBP
              ifdef ReEnterUsed
                btfsc  _Vars_Saved
                goto   AfterSave
                GetAddress  AfterSave, _RetAddr
                L?GOTO  _SavePBP                 ; Save PBP system Vars
                LABEL?L  AfterSave
                error ReEnterPBP must be INCLUDEd to use PBP type interrupts
            GetAddress  AfterUserRoutine, _RetAddr   ; save return address
            L?GOTO   Label                       ; goto the users INT handler
            LABEL?L AfterUserRoutine
            if (Reset == YES)
              CHK?RP   FlagReg
              bcf      FlagReg, FlagBit        ; reset flag (if specified)
            INT_ERROR  "INT_Handler"
    NoInt
          banksel  0
    PREV_BANK = 0
    #define INT_HANDLER(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      ifndef INT_Handler
    #define INT_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    ;---[Returns from a "goto" subroutine]--------(RetAddr must be set first)---
    #INT_RETURN  macro
          CHK?RP  _RetAddr
          movf    _RetAddr + 1, W  ; Set PCLATH with top byte of return address
          movwf   PCLATH
          movf    _RetAddr, W      ; Go back to where we were
          movwf   PCL
    ;_____________________________
    #define INT_RETURN  #INT_RETURN
      ifndef INT_Return
    #define INT_Return  #INT_RETURN
    #define int_return  #INT_RETURN
    #define Int_Return  #INT_RETURN
    #define Int_return  #INT_RETURN
    #define int_Return  #INT_RETURN
    ;----[Display not found error]----------------------------------------------
    INT_ERROR macro From
        error From -  Interrupt Flag ( FlagReg,FlagBit ) not found.
    ;---[Enable an interrupt source]--------------------------------------------
      ifndef INT_ENABLECLEARFIRST
        #define INT_ENABLECLEARFIRST 1             ; default to Clear First
      endif          ; use DEFINE INT_ENABLECLEARFIRST 0 to NOT clear First
    #INT_ENABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            ifdef INT_ENABLECLEARFIRST
              if (INT_ENABLECLEARFIRST == 1)       ; if specified
                MOVE?CT 0, FlagReg, FlagBit        ;   clear the flag first
            MOVE?CT  1, EnableReg, EnableBit       ; enable the INT source
            INT_ERROR  "INT_ENABLE"
    #define INT_ENABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Enable
    #define INT_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Disable an interrupt source]-------------------------------------------
    #INT_DISABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            MOVE?CT  0, EnableReg, EnableBit       ; disable the INT source
            INT_ERROR  "INT_DISABLE"
    #define INT_DISABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Disable
    #define INT_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Clear an interrupt Flag]-----------------------------------------------
    #INT_CLEAR  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            INT_ERROR "INT_CLEAR"
    #define INT_CLEAR(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Clear
    #define INT_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
  5. #45
    The USART section in the datasheet for your device will tell you if you should set/clear the TRIS bits for the TX/RX pins....
    I've misunderstood/misinterpreted the data sheet before. Seriously, I read the EUSART section and my eyes gloss over when they start making distinctions between half-duplex, full-duplex, synchronous, asynchronous...)
    ..If the chip supports open-drain mode then you just need to setup the TX pin to enable it at startup (ODCONC.6 = 1).
    There's no need to set and clear it, and you won't need to enable/disable TXEN anymore either...
    Something like..?
    TRISC.7=1
    ODCONC.6 = 1
    Loop:
    TX, RX, rinse repeat
    I would have thought you need to reset ODCONC.6 to "standard push/pull"...? (Possible example of not always understanding what the datasheet "means").
    ...If your pic has PPS you'll probably need to set that up too to assign the pin to the UART TXD function.
    Yes, I figured that much. There's just so many peripherals available (coming from a guy that started with a 16F628).
    EDIT: I just rechecked the EUSART section (starts at page 543), and they never mention ODCON (last occurence is at page 233).
    The datasheet says very little about ODCON:
  6. #46
    An open-drain or open-collector output pin is driven by a single transistor, which pulls the pin to only one voltage (generally, to ground). When the output device is off, the pin is left floating (open, or hi-z). A common example is an n-channel transistor which pulls the signal to ground when the transistor is on or leaves it open when the transistor is off.
    Open-drain refers to such a circuit implemented in FET technologies because the transistor’s drain terminal is connected to the output; open-collector means a bipolar transistor’s collector is performing the function.
    When the Open-drain transistor is off, the signal line is free to be driven low by another device, it generally will be pulled up by a resistor. The resistor prevents an undefined, floating state.
  1. Trying to emulate shift register
    By RuudNL in forum General
    Last Post: - 17th March 2013, 20:57
  2. pic+shift register+lcd
    By eworld in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2012, 06:11
  3. Long shift register
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 18th April 2009, 20:14
  4. Framing Error /w USART
    Last Post: - 27th February 2007, 02:34
  5. Replies: 15
    Last Post: - 30th January 2005, 04:58
