I2CWRITE "Label" option - what does it do?
Results 1 to 4 of 4
    SWITZERLAND (french speaking)
    Default I2CWRITE "Label" option - what does it do?
    I'm working on a piece of code I found in another thread about a DS3231 RTC.
    Unfortunately, the used I2CWRITE command has an optional label to jump to.
    I don't get what the label is there for.
    The manual says If the optional Label is included, this label will be jumped to if an acknowledge is not received from the I2C device.
    Okay, but, what does it mean?
    DS3231:
    GetTime:
         RtcI2cNack = 0
         I2CRead RTC_SDA,RTC_SCL,$D0,RtcTimeReg,[RtcMin,RtcHour],I2CNACK
    I2CNACK:
         RtcI2cNack = 1
    Roger
    Sep 2009
    Default Re: I2CWRITE "Label" option - what does it do?
    Exactly what is writen in manual
    I2C Slave send 1 bit response after each byte received. If that bit is missing, then command will jump to label. If label is not present, it will just ignore it, and keep sending data...
    If you want, you may include that label in case the I2C device fails to communicate. So you can give the user a message that something was wrong.
    I was missing this.
    Thanks for the info guys
    Roger
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 02:01
  2. Replies: 0
    Last Post: - 14th November 2013, 03:32
  3. Replies: 3
    Last Post: - 15th October 2012, 08:06
  4. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 04:14
  5. Error[115]...duplicate label..."debug"
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 8th April 2008, 09:29
