SOLVED - Breaking HSERIN into separate parts
Results 1 to 12 of 12
    Default SOLVED - Breaking HSERIN into separate parts
    SOLVED in post #6:
    https://www.picbasic.co.uk/forum/sho...164#post156164
    USART
    Is it "safe" to send HSEROUT header, data,
    then receive:
    - HSERIN header
    (depending on header, use proper data format)
    - HSERIN data
    Or should I send Header and Data on 2 separate transmissions?
    Objective:
    I'm looking for a safe and simple way to transfer data of varying lengths.
    Header is a prefix that identifies the data layout.
    Sep 2009
    Default Re: Breaking HSERIN into separate parts
    I used something like this
    On transmis side
    HSEROUT "DataStart:",Len, str data\Len, chksum
    on receive side
    HSERIN wait("DataStart:"), Len, str data\Len, chksum
    On transmis side
    on receive side
    Interesting. Do you have a sample code of how you process the string array at reception?
    I had been looking at HSEROUT in the manual, but I should have been looking at HSERIN; that has more options.
    Sep 2009
    I do not have it right now.
    String is just array. You can fill each byte separatly.
    My dilemma is having multiple record layouts, and having the receiving PIC figure out which format to use.
    Using an array long enough to fit the largest transmission seems like a waste to me. My messages will range from sending a single value, to the entire set (possibly 30 values).
    One alternative is to blindly use the longest possible array on reception, even if I only send one value. I have no clue if that opens up a can of worms.
    I see that you can add a LENGTH parameter, maybe that can be used (got some testing to do).
    I think I figured out what's written in plain English right in my face:
    STR ArrayVar\n{\c}
    Receive string of n characters optionally ended in character c
    It looks like I can:
    - define the array at the longest possible length,
    - stop reception on character c,
    This way I can embed a Data Layout Number at the start of the message, and use that to branch to code to treat the array properly.
    I understand quickly, you just have to be patient and explain it to me a whole bunch of times.
    EDIT: Length parameter has been removed, I only use StartOfData and EndOfData characters now.
    Yeah, i was waaaay overthinking this.
    Transmitting (16F18877):
    XmitStr                 CON "["
    XmitCode1               var BYTE
    XmitCode2               var BYTE
    XmitNumber              var BYTE
    XmitLen                 var byte
    XmitChecksum            var WORD
    XmitEOF                 CON "]"
        TX1STA.5 = 1
        XmitCode1  = "A"
        XmitCode2  = "A"
        XmitNumber = 8
        XmitLen    = 8
        XmitChecksum =  XmitStr + _
                        XmitCode1 + XmitCode2 + XmitNumber + XmitLen + _
                        NAV2_MHz_Standby + _
                        NAV2_KHz_Standby
        BlinkLED1 = 1
        hserout [   XmitStr, _
                    XmitLen, _
                    XmitCode1, _
                    XmitCode2, _
                    XmitNumber, _
                    NAV2_MHz_Standby, _
                    NAV2_KHz_Standby, _
                    XmitChecksum.BYTE1, _
                    XmitChecksum.BYTE0, _
                    XmitEOF]
        BlinkLED1 = 0
        while TX1STA.1 = 0              ' Check TRMT bit
        wend
        TX1STA.5 = 0
    Receiving (18F26K22):
    RecvStr                 con "["
    RecvLen                 var BYTE
    RecvCode1               var BYTE
    RecvCode2               var BYTE
    RecvNumber              var BYTE
    RecvChecksum            var WORD
    RecvEOF                 var BYTE
        hserin [ wait(RecvStr), STR RecvData\11\"]" ]
        RecvLen             = RecvData[0]
        RecvCode1           = RecvData[1]
        RecvCode2           = RecvData[2]
        RecvNumber          = RecvData[3]
    '           check Code1/Code2/Number, execute proper code for that record layout.
        NAV2_MHz_Standby    = RecvData[4]
        NAV2_KHz_Standby    = RecvData[5]
        RecvChecksum.byte1  = RecvData[6]
        RecvChecksum.byte0  = RecvData[7]
    It helps to send data 1 byte at a time, or else you get garbage.
    16F18877
    Transmitter Enabled/Disabled to have more than 1 PIC transmitting (using a Busy Line to determine which PIC can talk).
    '          Enable Transmitter
        TX1STA.5 = 1
    ... transmit ...
    '          Make sure all data is sent
        wend
    '          Disable Transmitter
        TX1STA.5 = 0
    Default Re: SOLVED - Breaking HSERIN into separate parts
    The stop character in the Hserin command is needed if you do not know the length of the string.
    Since you define the length at the beginning of the transmission, and then use it in the STR modifier, what is the point of "]" in that modifier? It will never engage!
    ... what is the point of "]" in that modifier? It will never engage!
    That was one area that had me overthinking USART. STR ArrayVar\n{\c}, receives a maximum of n bytes, unless it receives character c.
    If I misinterpreted the manual, I'd definitely appreciate being corrected before I code my entire project.
    Initially I was copying what Pedja was doing, but I've since dropped the Length parameter and use only the StartOfData and EndOfData delimiters. I have a LOT of different Data Layouts, and calculating Length was becoming tiresome, and a possible source of human error. It's also cumbersome when you modify the Data Layout.
    I am using variables in HSEROUT, an array (equal to the longest data layout) in HSERIN, which is then moved into variables depending on Header values; it's much more simple (for me).
    OK, if you drop length then makes sense.
    Using length variable in the STR modifier on the other hand, is very clever.
    OK, if you drop length then makes sense. ...
    Yeah, I updated my post with a comment to clear that.
    Using length variable in the STR modifier on the other hand, is very clever. ...
    I didn't field particularly clever after racking my brains trying to find the most efficient way to move data around.
  1. Replies: 3
    Last Post: - 14th October 2016, 23:07
  2. Replies: 3
    Last Post: - 22nd June 2015, 17:15
  3. Breaking out of for loops
    Last Post: - 17th March 2008, 01:49
  4. Replies: 5
    Last Post: - 28th June 2006, 22:32
  5. Breaking through pages in PIC16 Series
    By crematory in forum mel PIC BASIC Pro
    Last Post: - 1st August 2005, 14:49
