SOLVED - IOC works on B0 but not B5
Results 1 to 20 of 20
Threaded View
  1. #9
    Default Re: IOC works on B0 but not B5
    did i say ioc pin change is a bad way to do keys
    try this and compare results
    #CONFIG    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_OFF & _FCMEN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
    DEFINE OSC 32
    define  CCP4_REG     PORTD              ' PWM Pulse out to LCD contrast
    DEFINE  CCP4_BIT     2                  '   2N2907 PNP with 1K on base
    define  CCP3_REG     PORTD              ' PWM Pulse out to LCD backlight
    DEFINE  CCP3_BIT     3                  '   2N2222A NPN with 1K on base
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    WPUC   = % 00100000
    WPUB   = % 00110000
    TRISA  = % 00001111
    TRISB  = % 11111111
    TRISC  = % 11111111
    TRISD  = % 11110011
    IOCBN  = % 00100000
    PushSwitchA      VAR PortC.5      ;sw2
    PushSwitchB      VAR Portb.4       ;sw1
    PushSwitchC      VAR Portb.5
    InterruptLED     VAR Lata.4
    anotherLED       VAR Lata.5
    polLED           VAR Lata.6
    notherLED        VAR Lata.7
    ButtonWasPressed VAR WORD[2]
    lc var byte
        Pause 500                                       ' Let PIC stabilize
        InterruptLED = 0
        anotherLED   = 0
        HPWM 3,250,1953                 ' Pulse Contrast
        HPWM 4,150,1953                 ' Pulse Backlight
    Mainloop:
        lc=lc+1
        if lc==50 then
             polLED = !polLED
             lc=0
        ButtonWasPressed[0] =  (ButtonWasPressed[0]<<1) +  PushSwitcha
        ButtonWasPressed[1] =  (ButtonWasPressed[1]<<1) +  PushSwitchb
        if ButtonWasPressed[0] = $f then                    ' Check flag
             anotherLED = !anotherLED
        if ButtonWasPressed[1] = $f then                    ' Check flag
            notherLED = !notherLED
        if IOCBF then
             InterruptLED = !InterruptLED
            IOCBF = 0
        pause 10
    goto mainloop
    pps , my way works fine even with no capacitor on the switches
  1. Replies: 12
    Last Post: - 7th September 2024, 15:10
  2. Replies: 8
    Last Post: - 30th August 2024, 19:45
  3. Replies: 4
    Last Post: - 22nd March 2023, 11:32
  4. DS3231 works in one config, but does not works with other IC.
    Last Post: - 3rd December 2019, 19:52
