Can't get IOC on pin change working
Results 1 to 6 of 6
    Sep 2024
    Default Can't get IOC on pin change working
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    include    "DT_INTS-14.bas"
    include    "ReEnterPBP.bas"
    INT_LIST  macro      ;IntSource,  Label,    Type, ResetFlag?
            INT_Handler  IOC_INT,    _IOCinterrupts,    PBP,  yes
        INT_CREATE                      ;Creates the interrupt processor
    INTCON = 000000
    '          bit 7  GIE        Global Interrupt Enable bit
    '                                  1 = Enables all active interrupts
    '          bit 6  PEIE        Peripheral Interrupt Enable bit
    '          bit 5-1    Unimplemented: Read as ‘0’
    '          bit 0  INTEDG      Interrupt Edge Select bit
    PIE0 = 010000    ' PERIPHERAL INTERRUPT ENABLE REGISTER 0
    '          bit 7-6 Unimplemented: Read as ‘0’
    '          bit 5 TMR0IE: TMR0 Overflow Interrupt Enable bit
    '          bit 4 IOCIE: Interrupt-on-Change Interrupt Enable bit
    '                                  1 = Enables the IOC change interrupt
    '          bit 3-1 Unimplemented: Read as ‘0’
    '          bit 0 INTE: INT External Interrupt Flag bit
    IOCCP = 010000  ' INTERRUPT-ON-CHANGE PORTC POSITIVE EDGE REGISTER
    '          bit 7-0 IOCCP<7:0>  Interrupt-on-Change PORTC Positive Edge Enable bits
    '                                  1 = Interrupt-on-Change enabled on the pin
    '                                      for a positive-going edge. IOCCFx bit
    '                                      and IOCIF flag will be set upon detecting an edge.
    IOCCN = 000000  ' INTERRUPT-ON-CHANGE PORTC NEGATIVE EDGE REGISTER
    '          bit 7-0 IOCCP<7:0>  Interrupt-on-Change PORTC Negative Edge Enable bits
    '                                      for a Negative-going edge. IOCCFx bit
    ANSELA = 000000
    ANSELB = 000000
    ANSELC = 000000
    ANSELD = 000000
    ANSELE = 000000
    TRISA = 000000
    TRISB = 000000
    TRISC = 010000
    TRISD = 000000
    TRISE = 000000
    PushSwitch      VAR PortC.4
    InterruptLED    VAR LatC.2
    HeartbeatLED    VAR LatC.3
    ButtonWasPressed VAR byte
        Pause 500                                      ' Let PIC and LCD stabilize
        InterruptLED = 0
        ButtonWasPressed = 0
        IOCCF.4 = 0
    @ INT_ENABLE IOC_INT
        goto Mainloop
    IOCinterrupts:
        if IOCCF.4 = 1 then
            ButtonWasPressed = 1                        ' set a flag
            IOCCF.4 = 0
    @ INT_RETURN
    Mainloop:
        if ButtonWasPressed = 1 then                    ' Check flag
            InterruptLED = 1
        HeartbeatLED = 1
        HeartbeatLED = 0
        goto mainloop
    InterruptLED never lights up when I press PushSwitch, and the HeartbeatLED seems to hang for 2-3 seconds when I press.
    Default Re: Can't get IOC on pin change working
    You appear to have forgotten the % for bit definitions
    eg variable = %10100110
    not variable = 10100110
    congrats on posting your code in code tags
    while its unfortunate that the forum mangles % notation i guess that mangled binary notation is not your trouble
    you have neglected to tell us what pic chip you are using but looking at the config section it has PPS
    therefore dt-ints will not in all likelihood function for your chip without modifications
    secondly you have not set up the internal osc at all, that will cause a very slow default int osc to be used. depending on the pic chip you are using of course
    Dec 2010
    Melbourne Australia
    Richard,
    can you elaborate or provide some pointers for that? You're suggesting there's more mods needed than to simply assign the appropriate PPSs ?
    Troy
    can you elaborate
    nobody keeps dt-ints upto date, the pic world has moved on - pic int flags and enable bits have been changed/modified added to and relocated for enhanced core chips pic16f 1xxxxx
    see this
    https://www.picbasic.co.uk/forum/sho...change-working
    Dec 2010
    Melbourne Australia
    Thanks Richard,
    Troy
  1. IOC on pin going HIGH and LOW
    By Demon in forum Code Examples
    Last Post: - 30th August 2024, 20:30
  2. Replies: 8
    Last Post: - 30th August 2024, 19:45
  3. IOC on a ACD pin ?
    Last Post: - 28th August 2013, 01:11
  4. Replies: 1
    Last Post: - 12th May 2012, 12:37
  5. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 19:53
