OK, i have have done a bit more digging and come up with this:
Red VAR PORTB.1
Seconds var byte ' 0-59
Minutes var byte ' 0-5
Minutedelay var byte
Minutedelay = 2
counter = 0
For Minutes = 0 to Minutedelay
Gosub Delaymin
If Minutes = Minutedelay - 1 then gosub flash
Next Minutes
Delaymin:
For Seconds=0 to 59
Pause 1000
Toggle Red ' flashing light for reference
Next Seconds
Flash:
For loop = 1 to 5
red = 1
pause 125
red = 0
pause 250
red = 1
pause 125
red = 0
pause 250
Next loop
I have had to put the
in as it would not stop at the MinuteDelay variable. ie if i wanted it to stop at 2 minutes, it would stop at 3, if i wanted to stop at 3, it would stop at 4 etc etc.
Is there any other way to tidy up this routine?
Also, this routine is activated by, for argument sake, PORTC.0 going high. How would i place the abort code in. ie if the same button (PORTC.0) goes high during this routine, it stops the counting and jumps back to the main code awaiting an input instruction.
I have a CASE SELECT routine which selects different routines, depending on which button is pressed. This is just one of the routines.
Many thanks,
