4G sms module
Results 1 to 10 of 10
Thread: 4G sms module
    Dec 2010
    Melbourne Australia
    Default Re: 4G sms module
    Well, I purchased something and waiting for it to arrive. If it works, I promise to post it although I think there could be many options.
    Troy
    Dec 2010
    Melbourne Australia
    Aerostar,
    okay it arrived yesterday and it worked a treat. Almost a direct drop-in replacement for my older 3G module (starts message indexing at 1 instead of 0).
    https://www.aliexpress.com/item/1005002280354604.html
    I purchased the A7670E module which appeared to be the last one of but I probably could've used the A7670C just as effectively. There are cheaper modules, but this one is very versatile and allows 5V interfacing.
    So, only 4 wires required: pos & neg rails and the receive + transmit serial wires. Uses AT commands: https://www.ktron.in/wp-content/uplo...al_V1.06-4.pdf
    The module needs to be turned on (there's a microswitch button) which you can pull to ground via your PIC micro to avoid needing to manually press upon power up.
    My application is for my wife and I to gather the up or down status of our garage door ie. we leave the house and are unsure whether we remember to lower the door. This allows us to send a text message to the module and receive the status and to also lower the door via SMS if needed.
    Troy
    You could spare any MCU and programming with this:
    https://www.aliexpress.com/item/1005...Cquery_from%3A
    Provided the country you're about to deploy it in still has a working GSM network.... These days it's 4G, LTE or 5G.
    All the description says is "GSM" so I'll take it that's what they mean - literally. Which is probably also why it's soo cheap.
    On the specs does not say if it is compatible with 4G, LTE or 5G.
    So, yes I bet Henrik, you are right!
    Under the price it says
    SIM A7670C R2 A7670E R2 4G LTE cat 1 Module is Compatible With STM32, Raspberry pie, etc
    Note 4G LTE
    and
    If you scroll down the web page he gave it says
    Introduction:
    ●The A7670 series is the LTE Cat 1 module which supportswireless communication modes of LTE-TDD/LTE-FDD/GSM/GPRS/EDGE. It supports maximum 10Mbps downlinkrate and 5Mbps uplink rate.
    ●The A7670 series supports multiple built-in networkprotocols, which is suitable for main IOTapplications such as telematics, surveillance devices, POS,industrial routers, and remote diagnostics etc.
    ●It is designed for applications that need high throughput data communication in a variety of radio propagation conditions. Due to the unique combination of performance, security and flexibility, this module is ideally suited for many applications.
    I was referring to the one Ioannis linked to.
  1. 3642bh display module pinouts on tm1637 module
    By longpole001 in forum Schematics
    Last Post: - 31st July 2018, 19:09
  2. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  3. Replies: 11
    Last Post: - 19th August 2009, 16:23
  4. Replies: 1
    Last Post: - 27th July 2008, 07:14
  5. SMS message
    By angelika in forum mel PIC BASIC Pro
    Last Post: - 17th June 2005, 15:47
