IOC on pin going HIGH and LOW
Results 1 to 8 of 8
    Default IOC on pin going HIGH and LOW
    PIC 16F18877
    Custom DT_INTS-14.bas entry:
    ;---[16F1885x7x]------------------------------------------------------------
    ; #define IOC_INT      INTCON,IOCIF, INTCON,IOCIE  ;-- Int On Change
      #define IOC_INT      PIR0,IOCIF, PIE0,IOCIE      ;-- Int On Change       *
    Will turn LED on when pressed, and off when released:
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    include     "C:\PBP Includes\DT_INTS-14_16F1885x-7x.bas"
    include     "C:\PBP Includes\ReEnterPBP.bas"
    INT_LIST  macro      ;IntSource,  Label,     Type, ResetFlag?
            INT_Handler   IOC_INT,    _MyIOCinterrupts,    PBP,  yes
        INT_CREATE                      ;Creates the interrupt processor
    '                           Controlled by DT-INTS
    'INTCON = %10000000
    '           bit 7   GIE         Global Interrupt Enable bit
    '                                   1 = Enables all active interrupts
    '           bit 6   PEIE        Peripheral Interrupt Enable bit
    '           bit 5-1     Unimplemented: Read as ‘0’
    '           bit 0   INTEDG      Interrupt Edge Select bit
    'PIE0 = %00010000    ' PERIPHERAL INTERRUPT ENABLE REGISTER 0
    '           bit 7-6 Unimplemented: Read as ‘0’
    '           bit 5 TMR0IE: TMR0 Overflow Interrupt Enable bit
    '           bit 4 IOCIE: Interrupt-on-Change Interrupt Enable bit
    '                                   1 = Enables the IOC change interrupt
    '           bit 3-1 Unimplemented: Read as ‘0’
    '           bit 0 INTE: INT External Interrupt Flag bit
    IOCCP = %00010000   ' INTERRUPT-ON-CHANGE PORTC POSITIVE EDGE REGISTER
    '           bit 7-0 IOCCP<7:0>  Interrupt-on-Change PORTC Positive Edge Enable bits
    '                                   1 = Interrupt-on-Change enabled on the pin
    '                                       for a positive-going edge. IOCCFx bit
    '                                       and IOCIF flag will be set upon detecting an edge.
    IOCCN = %00010000   ' INTERRUPT-ON-CHANGE PORTC NEGATIVE EDGE REGISTER
    '           bit 7-0 IOCCP<7:0>  Interrupt-on-Change PORTC Negative Edge Enable bits
    '                                       for a Negative-going edge. IOCCFx bit
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00010000
    TRISD = %00000000
    TRISE = %00000000
    PushSwitch      VAR PortC.4
    InterruptLED    VAR LatC.2
    ButtonWasPressed VAR byte
        Pause 500                                       ' Let PIC stabilize
        InterruptLED = 0
        ButtonWasPressed = 0
    @ INT_ENABLE IOC_INT
        IOCCF.4 = 0
    Mainloop:
        if ButtonWasPressed = 1 then                    ' Check flag
            InterruptLED = 1
            InterruptLED = 0
        goto mainloop
    MyIOCinterrupts:
        if IOCCF.4 = 1 then
            if ButtonWasPressed = 1 then                ' toggle flag
            IOCCF.4 = 0
    @ INT_RETURN
    Default Re: IOC on pin going HIGH and LOW
    Using the IOC logic above, along with Bourns debounce circuit (10K/0.01uF) followed by a 74HC14, these are the signal speeds I was able to get using an ordinary pushbutton and EC11-type rotary encoder:
    Name:  Switch VS encoder.png
    Switch:
    33.9msec ON
    146.2msec ON to ON
    Encoder:
    2.13msec ON
    3.01msec ON to ON
    To keep things in perspective, I added a LED toggle in MainLoop.
    Heartbeat:
    2.12usec ON
    4.75usec ON to ON
    why the redundant extra schmitt trigger?
    in the pic 16F1885x family all input pins are ST by default unless you clear the INPUT THRESHOLD CONTROL bit in the INLVLx register
    why the redundant extra schmitt trigger? ...
    Because I started development using a 16F1937 and didn't notice the ST on the 16F18877.
    (runs over to the datasheet)
    EDIT: Wow! That PIC is amazing; every pin has ADC and ST. That's gonna help bring costs down from those 74HC14 ICs.
    unfortunately one of the very few enhanced core pic chips without INPUT THRESHOLD CONTROL.
    193x was a nice chip in its time but now comparing to 188xx seems so old...!
    And I have many in stock...
    Registers associated with Interrupts are in Table 7-1 on p. 153:
    Name:  16F1887xx interrupt registers.png
    From my observations, you need 2 entries in the DEFINES for 16F:
    - Result bit,
    - Enable bit.
    #DEFINE {DT-INT interrupt NAME} {result flag REGISTER}, {result flag bit}, {enable bit REGISTER}, {enable bit}
    For example:
    #DEFINE IOC_INT PIR0,IOCIF, PIE0,IOCIE
    I keep the IOC flags right alongside the pin definitions (this is a EC11-type rotary encoder; 2 shafts + pushbutton):
    ;--- Setup pins ----------------------------------------------------------------
    COM1_MHz_WiperA             var PortA.2         ' Outer
    IOC_COM1_MHz_WiperA_flag    var IOCAF.2         '       IOC flag
    COM1_MHz_WiperB             var PortA.3         ' Outer
    IOC_COM1_MHz_WiperB_flag    var IOCAF.3         '       IOC flag
    COM1_KHz_WiperA             var PortA.0         ' Inner
    IOC_COM1_KHz_WiperA_flag    var IOCAF.0         '       IOC flag
    COM1_KHz_WiperB             VAr PortA.1         ' Inner
    IOC_COM1_KHz_WiperB_flag    var IOCAF.1         '       IOC flag
    COM1_SPST                   var PortA.4         ' Swap
    IOC_COM1_SPST_flag          var IOCAF.4         '       IOC flag
    It makes it easier (for me) to make sure things are connected exactly where I think they are. It's also much easier to move things about on the pins.
  1. Replies: 10
    Last Post: - 14th April 2014, 20:47
  2. Replies: 8
    Last Post: - 31st March 2014, 20:16
  3. Use of HIGH and LOW for pin outputs
    By rnuke77 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2011, 18:40
  4. Replies: 5
    Last Post: - 14th May 2010, 03:21
  5. Reading if Pin is High or Low?
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 1st August 2005, 17:39
