16F18877 CONFIG with PPS register settings
Results 1 to 4 of 4
    Default 16F18877 CONFIG with PPS register settings
    32MHz internal
    Config:
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    Oscillator:
    DEFINE OSC 32
        OSCCON1 = %01100010
    '       bit 7   n/a
    '           6-4 NOSC    New Oscillator Source Request bits
    '                   110     HFINTOSC
    '           3-0 NDIV    New Divider Selection Request bits
    '                   0010    Clock divider = 4
        OSCCON3 = %00000000                 ' Default values
        OSCEN = %00000000                   ' Default values
        OSCFRQ = %00000110
    '       bit 7-3 n/a
    '           2-0 HFFRQ   Frequency Selection bits
    '                   110     32 MHz
        OSCTUNE = %00000000                 ' Default values
    PPS pin definitions to use CCP3 and CCP4 on Ports D2 and D3 respectively:
    PinD2   CON %011010                     ' Datasheet table 13-2
    PinD3   CON %011011
    CCP3PPS = PinD2                         ' CCP3 Peripheral input selection
    CCP4PPS = PinD3                         ' CCP4 Peripheral input selection
    PeripheralCCP3  CON %001011             ' Datasheet table 13-3
    PeripheralCCP4  CON %001100
    RD2PPS = PeripheralCCP3                 ' Pin D2 output source selection
    RD3PPS = PeripheralCCP4                 ' Pin D3 output source selection
    HPWM on pins D2 and D3:
        HPWM 3,160,1953                 ' Sample Pulses
        HPWM 4,180,1953
    Thanks go to TimB and Top204 on the Proton forum (that's where I got the Config from):
    https://protoncompiler.com/index.php?topic=528.0
    Aug 2011
    Default Re: 16F18877 CONFIG with PPS register settings
    With those config1 settings you really shouldn't need to program any of the osc registers in code... it should run at 32Mhz at startup
    Yup. I can confirm it will work without the register definitions in this case (LCDOUT and heartbeat LED working properly).
    NOTE: When moving a feature away from a pin, make sure to clear the PPS register for that pin.
    RB5PPS = 0                              ' Disable CCP3
    RB0PPS = 0                              ' Disable CCP4
    Or else you risk having all sorts of annoying surprises; like having a regular pulse coming out of what you thought was an input pin.
    In my case, I moved CCP3 and CCP4 to other pins and was trying to use B0 and B5 for a rotary encoder signal. Took me WAAAAY too long to realize what was going on, but a quick google and Ric over at Microchip had the answer:
    https://forum.microchip.com/s/topic/...ment=P-2930284
  1. 18F4550 Config settings
    By Ioannis in forum USB
    Last Post: - 16th December 2021, 18:43
  2. Replies: 1
    Last Post: - 8th March 2013, 09:29
  3. PIC16F886 Register Settings
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 29th July 2009, 17:52
  4. Config settings
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 18:24
  5. Register Settings
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 26th September 2007, 00:28
