How long does a Bourns/74HC14 debounce filter take
Results 1 to 4 of 4
    Default Re: How long does a Bourns/74HC14 debounce filter take
    I'm using 10K - 0.01uF, exactly like here:
    Name:  Bournes rotary encoder.png
    Along with Toshiba's TC74HC14AP Schmitt trigger (I'm guessing I'm supposed to look at propagation delay ? ):
    https://mm.digikey.com/Volume0/opasd...4/TC74HC14.pdf
    My math uses fuzzy logic at the best of times.
    propagation delay has virtually zero impact on the debounce time
    tor = RC [rc time constant] is the most significant factor by 3 orders of magnitude
    falling tor = 10k*0.01uF = 100uS
    propagation delay 0.021 uS
    debounce time is the time taken for the st input voltage to fall from vcc to the
    Negative threshold voltage for the SCHMITT trigger ie 2*tor
    rising tor = 20k*0.01uF = 200uS
    debounce time is the time taken for the st input voltage to rise from ground to the Positive threshold voltage for the SCHMITT trigger ie 2*tor
  1. Keypad with hardware debounce
    By Demon in forum General
    Last Post: - 27th December 2014, 02:47
  2. 8 bit parallel debounce routine
    By cncmachineguy in forum Code Examples
    Last Post: - 26th July 2011, 14:54
  3. TMR1 counter debounce?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 20th March 2008, 20:19
  4. Debounce routine comments?
    By gebillpap in forum General
    Last Post: - 20th February 2008, 19:56
  5. Debounce PULSIN?
    Last Post: - 6th March 2005, 14:45
