Solved - ELAPSED TIMER: TimerConst not defined
Results 1 to 12 of 12
Threaded View
    Default Solved - ELAPSED TIMER: TimerConst not defined
    SOLVED: See post #8:
    https://www.picbasic.co.uk/forum/sho...018#post156018
    Datasheet says the PIC 16F1936 has an "enhanced 16-bit TIMER1, TIMER2/4/6 are 8-bit", would that cause problems?
    I used this as reference:
    https://www.picbasic.co.uk/forum/sho...275#post130275. Hopefully I didn't miss something.
    My code:
    @ ERRORLEVEL -301   ; turn off ADC clock ignored message
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
     __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LVP_OFF
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    Include "Elapsed_INT.bas"
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    DEFINE OSC 32
    SPLLEN          CON %1                  ' PLL enable
    IRCF            CON %1110               ' to enable 8 MHz
    SCS             CON %00                 ' system clock determined by FOSC
    OSCCON = (SPLLEN << 7) | (IRCF << 3) | SCS
    DEFINE  LCD_DREG      PORTB             ' Set LCD data port
    DEFINE  LCD_DBIT      0                 ' Set starting data bit
    DEFINE  LCD_RSREG     PORTC             ' Set LCD register select port
    DEFINE  LCD_RSBIT     5                 ' Set LCD register select bit
    DEFINE  LCD_EREG      PORTC             ' Set LCD enable port
    DEFINE  LCD_EBIT      4                 ' Set LCD enable bit
    DEFINE  LCD_BITS      4                 ' Set LCD bus size
    DEFINE  LCD_LINES     4                 ' Set number of lines on LCD
    DEFINE  LCD_COMMANDUS 1000              ' Set command delay time in microseconds
    DEFINE  LCD_DATAUS    50                ' Set data delay time in microseconds
    define  CCP4_REG     PORTC              ' PWM Pulse out to LCD contrast
    DEFINE  CCP4_BIT     1                  '   2N2907 PNP with 1K on base
    define  CCP5_REG     PORTC              ' PWM Pulse out to LCD backlight
    DEFINE  CCP5_BIT     2                  '   2N2222A NPN with 1K on base
    ANSELA = %00000000
    ANSELB = %00000000
    TRISA = %00000111
    TRISB = %00110000
    TRISC = %10000000
    TRISE = %00000000
        HPWM 2,100,1953
        HPWM 1,180,1953
    @ INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts
        Gosub ResetTime                ' Reset Time to  0d-00:00:00.00
        Pause 500                           ' Let PIC and LCD stabilize
        LCDOUT $FE, 1 : Pauseus 1
        LCDOUT $FE, $80, "ROTARY ENCODER TEST" : Pauseus 1
        GOSUB StartTimer          ' Start the Elapsed Timer
    Mainloop:
        IF SecondsChanged = 1 THEN
            SecondsChanged = 0
            LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
        goto mainloop
    PBPX 3.1.6.3
    MCSP 5.0.0.5
    MPASMX assembler enabled
    EDIT: I've found this message "You'll need the ASM_INTS include from the original Elapsed Demo" here:
    https://dt.picbasic.co.uk/CODEX/ETimer
    Still looking....
  1. Elapsed Timer findings
    By Art in forum General
    Last Post: - 23rd August 2024, 07:40
  2. PIC16F18855 and DT elapsed timer
    By nomada in forum PBP3
    Last Post: - 18th October 2018, 06:58
  3. DT Elapsed Timer
    Last Post: - 15th December 2017, 00:21
  4. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 04:16
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 00:17
