(Yes, I'm reading up on Read-Modify-Write right now )
My entire code for 16F1936:
' Change log
' 2024-08-18  Convert from 16F1937
@ ERRORLEVEL -301   ; turn off ADC clock ignored message
@ ERRORLEVEL -306   ; turn off crossing page boundary message
' Default in file: PBP3_1\DEVICES\PIC16F1936.PBPINC                    *
' List in file:    PBP3_1\DEVICE_REFERENCE\PIC16F1936.INFO             *
' Note:            PIC18 devices, the __CONFIG directive has           *
'                    been superceded by the CONFIG directive           *
 __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
 __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LVP_OFF
;--- Defines -------------------------------------------------------------------
DEFINE OSC 32
DEFINE  LCD_DREG      PORTB             ' Set LCD data port
DEFINE  LCD_DBIT      0                 ' Set starting data bit
DEFINE  LCD_RSREG     PORTC             ' Set LCD register select port
DEFINE  LCD_RSBIT     5                 ' Set LCD register select bit
DEFINE  LCD_EREG      PORTC             ' Set LCD enable port
DEFINE  LCD_EBIT      4                 ' Set LCD enable bit
DEFINE  LCD_BITS      4                 ' Set LCD bus size
DEFINE  LCD_LINES     4                 ' Set number of lines on LCD
DEFINE  LCD_COMMANDUS 1000              ' Set command delay time in microseconds
DEFINE  LCD_DATAUS    50                ' Set data delay time in microseconds
define  CCP4_REG     PORTC              ' PWM Pulse out to LCD contrast
DEFINE  CCP4_BIT     1                  '   2N2907 PNP with 1K on base
define  CCP5_REG     PORTC              ' PWM Pulse out to LCD backlight
DEFINE  CCP5_BIT     2                  '   2N2222A NPN with 1K on base
DEFINE  HSER_RCSTA 90h                  ' Enable serial port & continuous receive
DEFINE  HSER_TXSTA 24h                  ' Enable transmit, BRGH = 1
Define  HSER_BAUD 115200
DEFINE  HSER_CLROERR 1                  ' Clear overflow automatically
DEFINE  HSER_SPBRGH  0
DEFINE  HSER_SPBRG  68
;--- Setup registers -----------------------------------------------------------
SPLLEN          CON %1                  ' PLL enable
IRCF            CON %1110               ' to enable 8 MHz
SCS             CON %00                 ' system clock determined by FOSC
OSCCON = (SPLLEN << 7) | (IRCF << 3) | SCS
BAUDCON.3 = 1                           ' Enable 16 bit baudrate generator
;--- Setup analog pins to digital ----------------------------------------------
ANSELA = %00000000
ANSELB = %00000000
'ANSELC = %00000000                     ' No analog on port C
'ANSELD = %00000000                     ' No port D
'ANSELE = %00000000                     ' No analog on port E
;--- Setup Port directions -----------------------------------------------------
TRISA = %00000111                       ' Pin A7 = ...available
                                        ' Pin A6 = ...available
                                        ' Pin A5 = ...available
                                        ' Pin A4 = ...available
                                        ' Pin A3 = ...available
                                        ' Pin A2 = SPST
                                        ' Pin A1 = WiperB
                                        ' Pin A0 = WiperA
TRISB = %00000000                       ' Pin B7 = iCSP clock
                                        ' Pin B6 = ICSP data
                                        ' Pin B5 = Blink LED1
                                        ' Pin B4 = Blink LED2
                                        ' Pin B3 = LCD data D7
                                        ' Pin B2 = LCD data D6
                                        ' Pin B1 = LCD data D5
                                        ' Pin B0 = LCD data D4
TRISC = %10000000                       ' Pin C7 = RX
                                        ' Pin C6 = TX
                                        ' Pin C5 = LCD RS
                                        ' Pin C4 = LCD EN
                                        ' Pin C3 = ...available
                                        ' Pin C2 = PWM LCD backlight
                                        ' Pin C1 = PWM LCD contrast
                                        ' Pin C0 = ...available
'TRISD = %00000000                       ' No port D
TRISE = %00000000                       ' Pin E3 = MCLR
;--- Setup constants -----------------------------------------------------------
;--- Setup pins ----------------------------------------------------------------
Enc1_WiperA         var PORTA.0
Enc1_WiperB         var PORTA.1
Enc1_SPST           VAR PORTA.2
BlinkLED1           VAR PORTB.5         ' Switch these ON/OFF to determine time
BlinkLED2           VAR PORTB.4         '   required to execute a section of code
;--- Setup variables -----------------------------------------------------------
Enc1_previous       var BYTE
Enc1_rotation       var BYTE
Enc1_direction      VAr BYTE
HPWMcontrast        var BYTE
HPWMbacklight       var BYTE
USARTcounter        VAr WORd            ' Used to show program is looping
Enc1_counter        VAr WORd            ' Used to display encoder movement
;--- Program initialization ----------------------------------------------------
    BlinkLED1 = 0
    BlinkLED2 = 0
    HPWM 2,100,1953                     ' LCD contrast (V0 pin)
    HPWM 1,180,1953                     ' LCD backlight (LED anode)
    USARTcounter = 0
    Enc1_previous = 0
    Enc1_rotation = 0
    Enc1_direction = 0
    Enc1_counter = 0
    goto Start
;--- Subroutines ---------------------------------------------------------------
Start:
    Pause 500                           ' Let PIC and LCD stabilize
    LCDOUT $FE, 1 : Pauseus 1
    LCDOUT $FE, $80, "ROTARY ENCODER TEST" : Pauseus 1
Mainloop:
    BlinkLED1 = 1                       ' Top of LOOP on Logic 2 probe
    BlinkLED2 = 0
    if USARTcounter < 65025 then        ' To show program is working
        USARTcounter = USARTcounter + 1
        USARTcounter = 0
'  Wiper Chart:
'     A   B
'     0   0
'     1   0  /\ CCW
'     1   1
'     0   1  \/ CW
'     0   0
' Careful, EC11 30 detents 15 pulses will move from 00 to 11
    if Enc1_WiperA = 0 and Enc1_WiperB = 0 then ' See wiper chart above
        if Enc1_previous = 01 then              ' 2 digits to follow chart better
            Enc1_direction = 1                  ' 1=CW, 0=CCW
            Enc1_rotation = 1                   ' Motion occurred
            if Enc1_previous = 10 then
                Enc1_direction = 0              ' 0=CCW
                Enc1_direction = 0              ' Not relevant without motion
                Enc1_rotation = 0               ' No motion occurred
        Enc1_previous = 00                      ' Save wiper position
    if Enc1_WiperA = 1 and Enc1_WiperB = 0 then
        if Enc1_previous = 00 then
            Enc1_direction = 1
            Enc1_rotation = 1
            if Enc1_previous = 11 then
                Enc1_direction = 0
                Enc1_rotation = 1
                Enc1_direction = 0
                Enc1_rotation = 0
        Enc1_previous = 10
    if Enc1_WiperA = 1 and Enc1_WiperB = 1 then
            Enc1_direction = 1
            Enc1_rotation = 1
                Enc1_direction = 0
                Enc1_rotation = 1
                Enc1_direction = 0
                Enc1_rotation = 0
        Enc1_previous = 11
    if Enc1_WiperA = 0 and Enc1_WiperB = 1 then
            Enc1_direction = 1
            Enc1_rotation = 1
                Enc1_direction = 0
                Enc1_rotation = 1
                Enc1_direction = 0
                Enc1_rotation = 0
        Enc1_previous = 01
    if Enc1_rotation = 1 then
        if (Enc1_WiperA = 0 and Enc1_WiperB = 0) or _
           (Enc1_WiperA = 1 and Enc1_WiperB = 1) then
            if Enc1_direction = 1 then
                Enc1_counter = Enc1_counter + 1     ' Turned 1 position CW
                if Enc1_counter > 0 then
                    Enc1_counter = Enc1_counter - 1 ' Turned 1 position CCW
    BlinkLED1 = 0                       ' Bottom of IFs on Logic 2 probe
    BlinkLED2 = 1
    hserout ["#:", DEC5 USARTcounter,_
             " C:", dec3 Enc1_counter,_
             " A:", DEC1 Enc1_WiperA,_
             " B:", DEC1 Enc1_WiperB,_
             " SW:", DEC1 Enc1_SPST, 10]
    BlinkLED1 = 0                       ' After HSEROUT on Logic 2 probe
    BlinkLED2 = 0
    LCDOUT $FE, $D4, "C:", dec3 Enc1_counter,_
                    "  SW:", DEC1 Enc1_SPST : Pauseus 1
    BlinkLED1 = 0                       ' After LCDOUT on Logic 2 probe
    BlinkLED2 = 0
    goto mainloop
The probes are attached to pin-side of 10K resistor on LEDs (10K shouldn't matter according to me).
Name:  Encoder probe b.png
Both LEDs are never HIGH at the same time, and yet they don't blink as expected...?
Name:  Encoder probe a.png
