This simple code fragment crashes and restarts MCU!
Results 1 to 7 of 7
    Default This simple code fragment crashes and restarts MCU!
    Hello.
    I have a small code for GPS, which works correctly, however, I've noticed the following:
    IF GPS is physically disconnected from the input, or I disable the "serin 2" line, main loop crashes after the first execution and MCU restarts from the beginning. This happens also on other physical boards, so it is not issue of this particular MCU. Other power supplies, other ways of output, like LCD screen instead of serout were tried, as well as hardware serial inputs and outputs - no changes. I also tried same code on 16F1939, 18F45K22 - same result.
    ;----[16F886 Hardware Configuration]--------------------------------------------
    cfg1 = _INTRC_OSC_NOCLKOUT    ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg1&= _WDT_ON                ; WDT enabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOR_OFF               ; BOR disabled
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
    cfg1&= _LVP_OFF               ; RB3 pin has digital I/O, HV on MCLR must be used for programming
    cfg1&= _DEBUG_OFF             ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins
      __CONFIG _CONFIG1, cfg1
    cfg2 = _BOR40V                ; Brown-out Reset set to 4.0V
    cfg2&= _WRT_OFF               ; Write protection off
      __CONFIG _CONFIG2, cfg2
    TRISA=%00000001  'SET A TO OUTPUT   1=input
    TRISC=%00001000   'set C3 for gps
    TRISB=%00011000   'set PortB to output
    ANSELH=%00000000   ' ADC OFF B
    ANSEL=%000000000 'configure PortA as digital except first 2
    ADCON1=%10000000  'adc justify
    OSCCON=%01110101  'SET FREQUENCY TO 8MHZ
    WPUB=%00000000    'turn off Pullups
    CM1CON0=0         'DISABLE COMPARATORS
    CM2CON0=0         'SAME HERE
    'CCP1CON=%01000000 ' configure pwm
    'PSTRCON=%00010110 'disable C pwm
    DEFINE OSC 8
    DEFINE ADC_BITS 12
    DEFINE ADC_CLOCK 5
    DEFINE ADC_SAMPLEUS 5
    gps_data VAR BYTE[80]  ' Buffer to store GPS data
    gps_char VAR BYTE      ' Character received from GPS
    time_data VAR BYTE[6]  ' Array to store the extracted time
    i VAR BYTE             ' Loop variable
    start_found VAR BIT    ' Flag to indicate start of time data
    ' Define the serial pins
    GPS_RX var PORTC.7     ' RX pin for GPS (Adjust according to your setup)
    GPS_TX var PORTC.5     ' TX pin for GPS (Adjust according to your setup)
    ' Initialize variables
    start_found = 0
    i = 0
     serout2 portc.5,84, ["Start ok", 10, 13]
     toggle portc.3 'test led
    mainx:
        ' Wait for data from GPS
        serin2 GPS_RX,85,[gps_char] 'If I remove this line or disconnect the GPS, MCU will crash!
        ' Store data in buffer
        gps_data[i] = gps_char
        i = i + 1
        ' Check if we have a complete line of data
        IF gps_char = 10 THEN
            ' Look for the $GPRMC sentence
           IF (gps_data[1] = "G") AND (gps_data[2] = "P") AND (gps_data[3] = "R") AND (gps_data[4] = "M") AND (gps_data[5] = "C") THEN
                ' Extract time from the sentence
                start_found = 1
                FOR i = 7 TO 12
                    time_data[i-7] = gps_data[i]
                NEXT i
            ' Reset buffer
            i = 0
        ' Display time data
        IF start_found = 1 THEN
            serout2 portc.5,84, ["Time: ", time_data[0], time_data[1], ":", time_data[2], time_data[3], ":", time_data[4], time_data[5], 13, 10]
            start_found = 0
        GOTO mainx
        high portc.3 'check if code comes to here
        stop
    Any ideas?
    Default Re: This simple code fragment crashes and restarts MCU!
    Also it will crash randomly even when GPS is connected. Here's how output looks:
    Time: 15:41:00
    Time: 15:41:01
    Time: 15:41:02
    Time: 15:41:03
    Time: 15:41:04
    Time: 15:41:05
    Time: 15:41:06
    Time: 15:41:07
    Start ok <------- it crashed and restarted here
    Time: 15:41:10
    Time: 15:41:11
    Time: 15:41:12
    Time: 15:41:13
    Time: 15:41:14
    So I think this is issue with arrays?
    Could be, easy to verify
        i = i + 1
       If i >= 80  'or whatever size you set the array to
         serout2 portc.5,84, ["Next char will overrun buffer"]
    not sure but first use of i and i+1 might overrun.
    Bombay, India
    I am not currentl with PBP, so, please refer the manual where necessary.
    It is most likely you are overrunning the specified receive buffer gps_data of 80 bytes as you are not doing any bounds checking to keep the data within that 80 bytes region. That is trashing the variables declared beyond the 80 bytes boundary.
    Ideally, you should receive characters until a terminating character is received like a CR or a $00 character (whichever method is used by the module) or the buffer limit is reached (i = 80 as per your code)
    edit:looks like I posted together with Henrik and amgen.
    Yes you're correct, i is overrun.
    This is AI generated code, by the way
    I added this:
        if i>=80 then
        serout2 portc.5,84, ["Oops!", 10, 13]
        i=0
    And now output looks like this with GPS connected:
    Oops!
    Oops!
    Oops!
    Time: 16:36:37
    Time: 16:36:38
    Time: 16:36:39
    Time: 16:36:40
    Oops!
    Time: 16:36:42
    Oops!
    And only "Oops!" with GPS disconnected, but there are no more resets...
    Bombay, India
    If you're gettings false data when GPS is disconnected, perhaps you have left the RX pin floating. Maybe you could see if adding a pull-up resistor eliminates that problem for you.
  1. MicroCode studio crashes while typing in code.
    By CuriousOne in forum General
    Last Post: - 27th August 2022, 14:47
  2. Is it possible to feed PBP variable data into ASM code fragment?
    Last Post: - 13th July 2017, 11:36
  3. Replies: 15
    Last Post: - 28th March 2014, 03:43
  4. ABS brake Pic code with 16f917 mcu
    By Foodie in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 21:58
  5. HSERIN restarts PIC18F2525?
    By breesy in forum mel PIC BASIC Pro
    Last Post: - 1st July 2006, 10:50
