Can not get my IF THEN statement to work
Results 1 to 10 of 10
    Aug 2005
    Houston, TX
    I have never been able to get an "If - Then" command to work using more that one condition in PIC Basic. That is no A and B. Only A, then another question.
    If I want to test a as 10 plus b at 20 for calling x:
    loop:
    if a = 10 then isb
    loopb:
    isb:
    if b = 20 then x
    goto loopb
    Nov 2004
    Saskatchewan Canada
    AND and OR are valid PicBasic commands used with IF/THEN and the proper syntax is "IF A=1 AND B=2 THEN" so if your's aren't working I don't think that is the reason. I'm just not good enough at reading other people's code to sort out the why.
    Sorry.
    Bart
    Perth, Australia
    shouldnt the line "if B6 = $31 and B7 < $35 then twenf" read:
    if B6 = $31 and B7 < $35 then GOTO twenf ?
    or is the GOTO not required when using an if statement?
    dw_pic's Avatar
    dw_pic Guest
    To my knowledge, "with picbasic, not pro"
    The picbasic compiler will see the added "goto" as a undeclared symbol and choke on it.
    the action is a goto, but the syntax is
    if X = true then label
    dw
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    The problem that I have with the statement is that when it is executed to the goto from the IF...THEN I used poke. When writing to a VAR I do not need the poke, but when I need to write to a address on the chip, per-say, that is when I would use the poke or peek. Example: POKE $86,0 for writing to the chip ;
    (NOT CORRECT)
    twenf:
    poke B6,$32: poke B7,$35:goto cs
    (CORRECT)
    twenf:
    B6 = $32 : B7 = $35 : goto cs
    OR
    twenf:
    B6 = $32
    B7 = $35
    goto cs
  1. END Statement
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 15:48
  2. How do I get DATA @ to work with a 18F452?
    Last Post: - 2nd February 2006, 11:35
  3. blink.bas help cant make any 18f's work
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 13th December 2004, 22:28
  4. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
  5. Interrupt Problem
    By FrankM in forum mel PIC BASIC Pro
    Last Post: - 20th June 2004, 16:53
