2nd hardware UART
+ Reply to Thread
Results 1 to 28 of 28
    Dec 2010
    Melbourne Australia
    Default 2nd hardware UART
    Has anyone here used the 2nd hardware UART on a PIC processor before? Are there any tricks to it? I, for the life of me, can't get the 2nd one working at all. 1st UART works fine, but no joy with the 2nd. Tried both the suggested PBPs defines and doing it manually with register settings suggested in the datasheet. Processor is a PIC18F26K83. Says it's supposed to have 2 (the way I read it)???
    Thanks for any tips,
    Troy
    Default Re: 2nd hardware UART
    my tip
    it works just fine if you do it properly
    Aug 2011
    You might want to post what you've tried so we can give you some 'tips'
    Dec 2010
    Melbourne Australia
    OSCFRQ = %1000 '64Mhz
    Define OSC 64
    ' Set receive register to receiver enabled
    ' Set transmit register to transmitter enabled
    DEFINE HSER_RXREG PORTC
    DEFINE HSER_RXBIT 4
    DEFINE HSER_TXREG PORTC
    DEFINE HSER_TXBIT 5
    DEFINE HSER_BAUD 9600
    'DEFINE HSER2_RXREG PORTB
    'DEFINE HSER2_RXBIT 3
    'DEFINE HSER2_TXREG PORTB
    'DEFINE HSER2_TXBIT 0
    'DEFINE HSER2_BAUD 9600
    'This works
    hSerout ["Test",13,10]
    'This doesn't
    hSerout2 ["Test",13,10]
    Dec 2010
    Melbourne Australia
    Apologies, here is the actual code:
    Define OSC 64
    PRECISION  CON 8 SYSTEM  '8 byte = 64 bit precision
    INCLUDE "N-Bit_Math.pbp"
    DEFINE HSER_RXBIT 4
    DEFINE HSER_TXBIT 5
    ANSELA = %00000000 'Everything Digital
    ANSELB = %00000000 'Everything Else Digital
    ANSELC = %00000000 'Everything Else Digital
    TRISB.0 = 0
    TRISB.3 = 1
    TRISC.4 = 1
    TRISC.5 = 0
    'works
    'doesn't work
    you don't appear to have set the portb pins used to digital [anselb =$f6]
    or not
    mcc sets the involved registers like this to match your settings
    TRISB = 0xFE;
    ANSELB = 0xF6;
    U2RXPPS = 0x0B; //RB3->UART2:RX2;
    RB0PPS = 0x16; //RB0->UART2:TX2;
    U2P1L = 0x00;
    U2P1H = 0x00;
    U2P2L = 0x00;
    U2P2H = 0x00;
    U2P3L = 0x00;
    U2P3H = 0x00;
    U2CON0 = 0xB0;
    U2CON1 = 0x80;
    U2CON2 = 0x00;
    U2BRGL = 0x82;
    U2BRGH = 0x06;
    U2FIFO = 0x00;
    U2UIR = 0x00;
    U2ERRIR = 0x00;
    U2ERRIE = 0x00;
    Last edited by richard; - 13th August 2024 at 01:05. Reason: oh you posted again when i reading the data sheet
    Dec 2010
    Melbourne Australia
    I'm guessing this is a reply to my 1st code post which I inadvertently cut the TRIS settings in my (hastily) attempt for reader friendly pruning, but I can assure you every port was set to digital all the time. What's more, the 2nd UART was originally configured to the same pins as the 1st. When my head was too sore from banging against that wall, I switched the 1st UART to those pins and voila, they worked.
    Troy
    or not
    TRISB = 0xFE;
    ANSELB = 0xF6;
    U2P1L = 0x00;
    U2P1H = 0x00;
    U2P2L = 0x00;
    U2P2H = 0x00;
    U2P3L = 0x00;
    U2P3H = 0x00;
    U2CON0 = 0xB0;
    U2CON1 = 0x80;
    U2CON2 = 0x00;
    U2BRGL = 0x82;
    U2BRGH = 0x06;
    U2FIFO = 0x00;
    U2UIR = 0x00;
    U2ERRIR = 0x00;
    U2ERRIE = 0x00;
    I'm far from an expert in this space. And haven't used the second USART port on a PIC
    But maybe PMD5 register for UART2 isn't being set correctly by picbasic??
    bit 5 U2MD: Disable UART2 bit
    1 = UART2 module disabled
    0 = UART2 module enabled
    bit 4 U1MD: Disable UART1 bit
    1 = UART1 module disabled
    0 = UART1 module enabled
    extremely unlikely
    note power on defaults for PDM5
    did you try setting uart regs like mcc suggests ?
    note uart registers
    Dec 2010
    Melbourne Australia
    Regarding setting the regs directly: this is what I've tried (note this is set to 115200 baud as that was the original objective)
    Define OSC 64
    'Use for hardware serial comms to SD card module
    'Configure UART Control Register 0
    U2CON0.7 = 1 'BRGS = 1 (high speed baud generator)
    U2CON0.6 = 0 'ABDEN = 0 Auto-baud Detect Disabled
    U2CON0.5 = 1 'TXEN: Transmit Enabled
    U2CON0.4 = 1 'RXEN: Receive Disabled
    U2CON0.3 = 0 '0000 = Asynchronous 8-bit UART mode
    U2CON0.2 = 0 '0000 = Asynchronous 8-bit UART mode
    U2CON0.1 = 0 '0000 = Asynchronous 8-bit UART mode
    U2CON0.0 = 0 '0000 = Asynchronous 8-bit UART mode
    U2CON1.7 = 0 'Turn Serial port 2 off for baud setting
    U2BRGL = 138  'Baud Divisor low byte
    U2BRGH = 0    'Baud Divisor high byte
    U2RXPPS = %1011 'Assign UART RX pin to RB3
    RB0PPS = %010110  'Assign UART2 TX pin to RB0
    U2CON1.7 = 1 'Turn Serial port 2 on
    'Configure AN2 as Analog Inputs (PortA2)
    ANSELB = %00000000 'Everything Digital
    TRISB.0 = 0 'SD_Card_TX Hardware UART
    TRISB.3 = 1 'SD_Card_RX Hardware UART
    That doesn't provide any joy either.
    I was going to say that you need to unlock the PPS before trying to configuring it but reading the datasheet it looks like it is unlocked at POR - I've always thought it was the other way around.
    Anyway, here's the relevant parts from a project of mine which uses both UARTS, in this particular case I even use the PPS peripheral to switch UART2 pins around to two different devices. Using HSEROUT / HSEROUT2 in the code it worked out fine. This is for a 67K40 so it won't match your setup but perhaps it can provide some pointers.
    ' PPS Unlock
    PPSLOCK = $55
    PPSLOCK = $AA
    @ BCF PPSLOCK, PPSLOCKED
    RC6PPS = $0C                                ' We want PORTC.6 as EUSART1 TX
    RX1PPS = %00010111                          ' We want PORTC.7 as EUSART1 RX
    RG7PPS = $0E                                ' We want EUSART2 TX on PortG.7
    RX2PPS = %00110010                          ' We want EUSART2 RX on PortG.2
    ' Since we're switching UART pins around during runtime we need to leave the PPS lock open.
    'PPSLOCK = $55
    'PPSLOCK = $AA
    '@ BSF PPSLOCK, PPSLOCKED
    ANSELA = %00110000                          ' RA4, 5 analog, rest digital
    ANSELB = 0
    ANSELD = 0
    ANSELE = 0
    ANSELF = 0
    ANSELG = 0
    ' Setup for EUSART1
    RCSTA1 = $90                                ' Enable serial port & continuous receive
    TXSTA1 = $24                                ' Enable transmit, BRGH = 1
    SPBRG1 = 64                                 ' 19200 Baud @ 64MHz, 0,04%
    SPBRGH1 = 3
    BAUDCON1.3 = 1                              ' Enable 16 bit baudrate generator
    ' Setup for EUSART2
    RCSTA2 = $90                                ' Enable serial port & continuous receive
    TXSTA2 = $24                                ' Enable transmit, BRGH = 1
    SPBRG2 = 138                                ' 115200 Baud @ 64MHz, -0,08%
    SPBRGH2 = 0
    BAUDCON2.3 = 1                              ' Enable 16 bit baudrate generator
    TRISC.6 = 0                                 ' UART1 TX
    TRISC.7 = 1                                 ' UART1 RX
    TRISG.7 = 0                                 ' UART2 TX
    TRISG.2 = 1                                 ' UART2 RX
    mcc suggests different baud-gen figures that what you have used
    mcc
    U2BRGL = 0x82;
    U2BRGH = 0x06;
    Dec 2010
    Melbourne Australia
    mcc
    U2BRGL = 0x82;
    U2BRGH = 0x06;
    Yes Richard, I realise that *if* I was operating in 9600 baud, but I noted at the top of that register post I was setting everything to 115200 originally and that pruned snippet of the register setting code was copy-&-pasted from my original attempts at getting this to work. Apologies for not updating those values to make them consistent with the previous posts utilising PBP defines for the config. I did have my terminal receiver running on the correct baud for the settings irrespective.
    One thing I've noticed since is the Hserout2 statement is hanging/crashing my code.
    Sending a character to the U2TXB register directly *does* work - at least at 9600 baud.
    Troy
    Dec 2010
    Melbourne Australia
    Thanks Henrik,
    I'll see if there's anything there that I've maybe missed.
    Cheers,
    Troy
    Dec 2010
    Melbourne Australia
    and just another update to clarify:
    I can send characters through the 2nd UART by sending them directly to the 2nd UARTs transmit register (even at 115200 baud).
    To achieve that, I need to manually set the UART control registers, using PBP defines doesn't seem to work for that.
    Hserout2 seems to be crashing my programs on this processor (PIC18F26K83)
    Everything is dandy with the 1st UART. I can configure it both ways and utilise hserout without issue.
    Troy
    ps: these current tests are being done on a PIC that's completely isolated from all other components. The only connections is the x5 inline serial wires and the minimum 2 serial test wires to the output.
    In my experience the PBP HSER Defines doesn't generate any output (ie ASM code) code unless there's also a HSEROUT statement in the code - which seem to match what you're seeing. So you can't use the DEFINE directive to configure the UART unless you're also using HSEROUT.
    The fact that you CAN spoonfeed the UART and get data out means you DO have PPS and the UART itself configured properly so HSEROUT2 "should" work. Like I said, I've successfully done it on a K40 series so it must be something specific to this device or device series.
    And....looking at the generated code for HSEROUT2 on a K83 here's part of it:
    000004                02884 HSEROUT2 ;movlb 15              ; Set bank select to 15 to pick up any SFRs not in Access bank
    000004 0139           02885         banksel  PIR6            ; Set bank for PIR3
    000006 0004               M         clrwdt
    000008 ABA6           02887         btfss   PIR6, U2TXIF    ; Wait till ready
    00000A D7FD           02888         bra     hserout2loop
    00000C 013D           02913         banksel  U2TXB           ; Set bank for TXREG2
    00000E 6FD2           02914         movwf   U2TXB          ; Send the char
    000010 80D8           02915         bsf     STATUS, C       ; Set no timeout for Serout2mod
    000012 EF0B F000      02916         goto    DUNN            ; That's it
    U2TXIF has the value of 5 which is correct (U2TXIF is bit 5 in the register) but it's looking at bit 5 in PIR6 which is wrong. U2TXIF is in PIR7.
    At this point I'm not sure where the actual error comes from and if it's something you or me can fix by simply editing a file or if it's buried in the exectuable of the compiler.
    EDIT: I think the compiler is using the pbp_pic18FxxK42.lib library file when compiling for the K83 as well because in IT is the reference to PIR6 in the HSEROUT2 function (and HSERIN2 as well) which, for the K42, is correct. For K83 it is not.
    I guess we can bodge this by editing the K42.lib file but then it won't work for K42 devices so, yeah... :-(
    Aug 2011
    good catch Henrik.
    I wouldn't do that. There are a lot more differences between the K42 and the K83 than just the U2IF flag... the K83 should really have its own set of libs.
    You can specify which library to use for a device in the *.pbpinc file.
    For example PIC18F26K83.PBPINC specifies
    LIBRARY "pbp_pic18FxxK42_Long"
    LIBRARY "pbp_pic18FxxK42"
    Aah, right, now that you mention it I remember seeing that information somewhere - which turned out to be in post #8 in a thread on MeLabs forum. Things like this really should be in the manual.
    Anyway, that means that we have a chance of fixing issues like these in case MeLabs won't. Thanks tumbleweed!
    Dec 2010
    Melbourne Australia
    Thanks Henrik,
    As Tumbleweed said: good catch! Okay, it's probably a bit beyond my paygrade to fix, but at least that sheds some light on the root cause.
    Cheers,
    Troy
    Charles promissed that he would try to fix any issues found with the exixting version of PBP.
    Maybe you can report that to him or the melabs forum.
    Dec 2010
    Melbourne Australia
    Thanks Ioannis,
    I'll endeavour to contact Charles and pass on the issue. As this is pretty much my go-to processor these days, it would be nice to have the issue fixed.
    Cheers,
    Troy
    Then you may report back,
    Dec 2010
    Melbourne Australia
    good catch Henrik.
    I've started email dialogue with Charles, but to this point raised by Tumbleweed: I will say I've used this processor a lot and I reckon I've used close to 90% of its peripheral functionality (without issue), so the K42 libraries must be very close to being a perfect match I would think.
    edit: although on further reflection, a lot of that was done in a more direct (register access) sense.
    Cheers,
    Troy
    Aug 2011
    There are a few slight peripheral differences between the two, but most of the changes have to do with the location and layout of the interrupt bits in the various PIE, PIR, and IRP regs.
    Dec 2010
    Melbourne Australia
    Okay, thanks, that's good to know.
    I've received some modified or new libraries from Charles with the required include files. Initial testing is showing no issues with transmitting on the 2nd UART. I've only cranked the baud up to 38400, but so far, so good. I only mentioned the 2nd UART issue to him, so I don't know how broadly he looked at the other interrupt registers with making the mods.
    Troy
    if it worked at 38400 then problem is solved. Speed is irrelevant to the issue of wrong FSRs.
    I am pretty sure Charles won't object in posting the corrected library file(s) on the forum.
    Dec 2010
    Melbourne Australia
    PBP_TEST.zip
    I think I've done this correctly. Thanks Charles for this.
    Cheers,
    Troy
    Dec 2010
    Melbourne Australia
    Oh, and special thanks again to Henrik for pinpointing the particular code. That helped a lot.
    Troy
  1. PID-filter routine (2nd try).
    By HenrikOlsson in forum Code Examples
    Last Post: - 3rd October 2018, 07:53
  2. Setup baudrate on hardware uart on 18F4520
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 00:31
  3. crucial error in a 90% working hardware uart
    By mimmmis in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2008, 14:18
  4. Serial Port Complete 2nd Edition
    By Bruce in forum Serial
    Last Post: - 8th November 2007, 15:28
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 21:55
Members who have read this thread : 13
