Timing of heartbeat LED is off
Results 1 to 5 of 5
    Default Timing of heartbeat LED is off
    Migrated my test code from a 18F26K22 (max 3Kohm impedance on ADC) to a 16F1937 (max 10K).
    Datasheet: https://ww1.microchip.com/downloads/...ets/41364E.pdf
    32 MHz internal clock is on page 74
    I tried a gazillion permutations of the clock settings but I can't seem to get it to blink ON at 1 second intervals.
    Pause 15 takes about 1 second from ON to ON.
     __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_LO & _LVP_OFF
    DEFINE IRCF = %1110                 ' to enable 8 MHz
    DEFINE SCS = %00                    ' system clock determined by FOSC
    DEFINE OSC 32
    'DEFINE TUN = %000000
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000   ' E3=MCLR
    LEDblink    var     PORTB.5
        LEDblink = 0
    Mainloop:
        if ledblink = 0 then
            LEDblink = 1
            LEDblink = 0
        Pause 15
        goto mainloop
    I bow in humbleness and await the appropriate mockery.
    Default Re: Timing of heartbeat LED is off
    none of which are known PBP defines
    which means that the chips osc is running with POR values
    what are the POR values
    fosc= 0.5 MHz
    osccon = ( IRCF << 3) | SCS
    might work
    Aug 2011
    First off, you should use CON to define a numeric constant instead of DEFINE
    Next, since the intosc defaults to 500KHz at startup, that's outside the range of the 4xPLL which is spec'd from 4MHz-8MHz.
    While it might work, I'd leave the CONFIG setting for the PLL off and enable it when you change the osc freq
    Something like this should work:
     __CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LVP_OFF
    DEFINE OSC 32
    ' OSCCON register settings
    SPLLEN CON %1           ' PLL enable
    IRCF   CON %1110        ' to enable 8 MHz
    SCS    CON %00          ' system clock determined by FOSC
    OSCCON = (SPLLEN<<7) | (IRCF<<3) | SCS
    Thanks guys. I've been away for far too long.
    Tumbleweed's code worked on the first try.
  1. Timing out DT's Blinking Led
    By tazntex in forum General
    Last Post: - 28th May 2010, 17:41
  2. LED Bargraph chip (guitar LED bling-age) ..do with a PIC?
    Last Post: - 12th July 2009, 23:15
  3. Heartbeat LED
    By ecoli-557 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2009, 14:05
  4. Replies: 3
    Last Post: - 5th December 2008, 15:00
  5. LED timing
    By elen-group in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 10:51
