I'm a bit confused about using the ICD feature of the PICs that support ICD. I have managed for years using the serial DEBUG command to work out my bugs but have recently become interested in the ICD feature. A project I just completed used a 16F628 and while I still had it on the protoboard I thought I would see if I could get the ICD to work. I already had a MAX232 converter set up so it was a simple matter to give it a try. I am using MicroCode Studio and PicBasic Pro with a Warp13 programmer (I was not using ICSP). Using Bruce Reynolds' posting on his site I was able to get a simple program to work but when I tried it on a "real" program it would hang and stop running. In Bruce's circuit he uses the RX/TX pins on the '628 but I see that Microchip's AN DS51242A says that the ICD uses RB6 and RB7. I have also found reference to adding a NOP as the first executable instruction and also adding an INCLUDE ICDDEFS.BAS. My copy of PBP has several variations of this include file, none of which say they are for the '628.
From what I can gather the Microchip ICD2 can connect to the ICSP pins and act as a programmer and then as a debugger, I assume using MPLAB. So my question is this:
Will the ICD2 work with Microcode Studio and PicBasic Pro and provide programming and debugging functions?
Is there something better than the ICD2 ?
Many thanks,
Mark
