Has anyone played around with the BMI088 IMU? Or possibly a similar IMU from Bosch? I'm having trouble getting valid data using I2C from it. I've run some code to read the registers from both the accelerometer (address=$18) and the gyro (address=$68), but get back $20 (dec 32) for all registers.
I have it configured for I2C with the following pins:
Pin 5 (CSB2) - NC
Pin 7 (PS) - VDD
Pin 10 (SD02) - GND
Pin 14 (CSB1) - VDD
Pin 15 (SD01) - GND
Section 6.2 of the datasheet (under the "I2C Read Access" heading at the bottom of page 50) along with figure 5 seems to indicate I need to perform an I2C write command to the relevant address to specify the starting register, then perform an I2C read command to the same address without specifying a register to get the data. Is my interpretation of this correct? I have posted Figure 5 for convenience below:
I am using a 18F25k20 and the relevant parts of the code I have used to date is below:
#config
__CONFIG _CONFIG1H, _FOSC_HSPLL_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
__CONFIG _CONFIG2H, _WDTEN_OFF_2H & _WDTPS_512_2H
__CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _HFOFST_ON_3H & _MCLRE_OFF_3H
__CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
'serial comm pins
PIN_OUT  var    PORTb.3
PIN_IN   var    PORTb.2
'BMI088 I2C pins
MPUCLK   var    PORTa.4
MPUSDA   var    PORTa.5
'variables
tmpbyte  var byte
'MPU sensor variables
mpu_aadr var byte
mpu_gadr var byte
mpu_areg var byte
mpu_greg var byte
ANSEL = %00000000     ' Configure unused analog inputs for digital I/O
ANSELH = %00000000    ' Configure unused analog inputs for digital I/O
TRISA = %00000011    ' set porta to digital output except push-button pins a.0 and a.1
TRISB = %10000101    ' set portb to digital input or output (b.7=eeprom DQI=input; b.2=serin=input; b.0=ppm in=input)
TRISC = %00000000    ' set portc to digital input or output
'BMI088 constants
GYROREAD	con	$68
AXCELREAD	con	$18
ACC_PWR_CNTL	con	$7D
ACC_PWR_CNF	con	$7C
STARTAX 	con	$12
STARTGX 	con	$02
'configure accel
mpu_aadr=AXCELREAD
mpu_gadr=GYROREAD
mpu_areg=ACC_PWR_CNTL
I2CWRITE MPUSDA,MPUCLK,mpu_aadr,mpu_areg,[4]
pause 1
mpu_areg=ACC_PWR_CNF
I2CWRITE MPUSDA,MPUCLK,mpu_aadr,mpu_areg,[0]
mpu_areg=STARTAX
serout2 PIN_OUT,6,["MPU REGS",13,10]
for mpu_areg=0 to 126
I2CREAD MPUSDA,MPUCLK,mpu_aadr,mpu_areg,[tmpbyte]
serout2 PIN_OUT,6,[dec mpu_aadr," ",dec mpu_areg," : ",DEC tmpbyte,13,10]
pause 1
next mpu_areg
for mpu_greg=0 to 126
I2CREAD MPUSDA,MPUCLK,mpu_gadr,mpu_greg,[tmpbyte]
serout2 PIN_OUT,6,[dec mpu_gadr," ",dec mpu_greg," : ",DEC tmpbyte,13,10]
pause 1
next mpu_greg
Any help is appreciated!
Thanks!
