Can we PWM an LED backlight on LCD module
Results 1 to 31 of 31
    Default Re: Can we PWM an LED backlight on LCD module
    I would not trust those chinese modules for serious projects. Rather design your own based on the TI or Microchip App. Notes for you specific needs. ...
    Well, that's disappointing. I looked only at Mouser, the IC alone is over $6 and most of the discrete components are not available. I don't know enough if I can replace them with components.
    8V–24V to 5V/3A Buck Converter, through-hole, Page 7
    https://www.microchip.com/content/da.../AN15-APID.pdf
    And the SMD designs had a LOT less power (my first choice, to have them fully assembled by JLCPCB). Microchip's app note dates from March 2001, gonna check out TI...
    Another idea would be to use a low drop linear regulator for 5 volt and use the cheap switch mode ones to lower the 24 volts down to 6-7 volts. That way power losses on the low drop would be minimal and still you will have good quality noise free 5v line.
  1. 24v DC to 12v DC converter for LED backlight
    By PJALM in forum Schematics
    Last Post: - 10th March 2012, 08:37
  2. Electroluminescent LCD backlight
    By Demon in forum Schematics
    Last Post: - 9th May 2011, 08:45
  3. LCD Backlight Proper Wiring
    By DavyJones in forum General
    Last Post: - 26th July 2009, 23:01
  4. Lcd Backlight
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 05:00
  5. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 13:18
