Determining trace/via/wire current capability
Results 1 to 15 of 15
    Default Determining trace/via/wire current capability
    Default Re: Determining trace/via/wire current capability
    Valuable source of info.
    Thanks for sharing,
    If you want to increase trace/via capacity without increasing their size (maybe it complicates the rest of your circuit), just make more.
    In my case, the 7805 voltage regulator takes the brunt of all components downstream, so that's where I increased their number.
    Sep 2009
    Put vias under component. Make bottom copeer pad large, and you have much better heatsink capabilites.
    Make via also untinted ut botom, so you can fill it with solder. For my taste your trace to via are too small(I know it is only signal, but...).
    I understand that you use Eagle.
    How can you prevent solder mask at the area of the VIAS under the smd component?
    Sep 2009
    Yes it is eagle...
    Sep 2009
    Also, you can draw any shape on that layer, and solder mask will be removed from that area.
    Great!
    Thank you,
    How is this?
    I went one further using vias after adding cooling; grounding the VSS pin on the voltage regulator with 3 large vias.
    This way it doesn't mess up the smaller vias I have on signal traces and VSS pins on tiny SMD ICs.
    CORRECTION:
    These are labelled backwards. The 7805 uses the TO-263 package and the Hexfet uses D2Pak (in my project).
    ... For my taste your trace to via are too small(I know it is only signal, but...).
    JLCPCB can support up to 0.15 vias. I'm using 0.3 hole/0.5 pad since I'm using 2 layer PCBs.
    https://jlcpcb.com/capabilities/pcb-capabilities
    I'm not finding any "ideal dimension" for signal traces on the web...? They seem unanimous to say "however small your PCB fabricator can handle".
    I'm using:
    - 0.2 traces default,
    - 0.3 for USART/USB,
    - 0.3 for VDD.
    PCB design is a bit of art. So, rules do apply but you can bend them (within reason of course) using common sense.
    Nice touch the cooled grounding. Never thought of that. Though I do not know how much will contribute in cooling if the main tab is big enough.
    Sep 2009
    Top is usualy bit tight with space, So I make GND al large as I can on bottom.
    Uart usualy don't require any special routing. I usualy use trace width of smalest IC pad.
    For USB it depends on lenght. It usualy doen't meter. But if it is long, it is critical to have diff pair with proper impedance....
    ... Nice touch the cooled grounding....
    The vias in the VSS pin is not for cooling; it's just to get the current to the bottom side with more via conduit.
    If I increase VSS via size, it messes up my spacing close to the TSSOP ICs.
    ...USB it depends on lenght. It usualy doen't meter. But if it is long, it is critical to have diff pair with proper impedance....
    I read that people have been getting away with what they consider sloppy traces.
    My USB traces are 20cm long, running side-by side, far from any large current. My application does not have to support USB 3.0, 2.0 is plenty fast for me.
  1. Determining which command caused SERIN2 to trigger?
    Last Post: - 17th April 2023, 09:24
  2. Determining variable length (number of digits) possible?
    Last Post: - 21st December 2020, 21:05
  3. Determining how much RAM is available?
    By Art in forum mel PIC BASIC Pro
    Last Post: - 20th February 2012, 17:04
  4. Replies: 6
    Last Post: - 20th November 2011, 23:59
  5. Determining LONG compiler
    Last Post: - 10th September 2011, 20:19
