Optimizing memory usage for ARRAYWRITE statement?
Results 1 to 2 of 2
    Default Optimizing memory usage for ARRAYWRITE statement?
    Hello.
    In my code I have to store a lot of textual variables inside code memory. For example:
    if cvladi=1 then arraywrite botline, ["Rainbow         "]
    if cvladi=2 then arraywrite botline, ["Sunset          "]
    if cvladi=3 then arraywrite botline, ["Amsterdam       "]
    if cvladi=4 then arraywrite botline, ["Fire            "]
    if cvladi=5 then arraywrite botline, ["Jet engine      "]
    Each arraywrite statement here, when writing 16 bytes of data into array, consumes 46 bytes of code memory when compiled.
    I do not have technical capabilities to attach external EEPROM or replace the main IC at this moment. The PIC I'm using is 16F1939 with 16K of program memory. I have to do a lot of arraywrites of 16 bytes of data - 146 times in whole program, so, 6716 bytes are used instead of 2336, is there a way to somehow compact all this, considering existing hardware limitations?
    Default Re: Optimizing memory usage for ARRAYWRITE statement?
    as has been pointed out many times, use the flash memory
    https://www.picbasic.co.uk/forum/sho...ithin-PBP-code
  1. Replies: 6
    Last Post: - 25th October 2022, 17:49
  2. MPLAB ICD Memory Usage Gauge Issues
    By readitaloud in forum mel PIC BASIC Pro
    Last Post: - 1st August 2011, 09:04
  3. Optimizing IR range
    By ardhuru in forum Schematics
    Last Post: - 12th January 2011, 04:39
  4. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  5. MPLAB IDE Memory Gauge usage?
    By gabrielg74 in forum General
    Last Post: - 5th December 2005, 18:52
