Addressing multiple PORTs using one Variable
Results 1 to 32 of 32
    Default Re: Addressing multiple PORTs using one Variable
    Having this limitations in mind, I started my project addressing one string at the time and I've got plenty of time to display a minute based clock. Since all strings use the same common code and therefore the same variables, I can only differentiate them using different ports.
    a 16f690 has 3 ports A,B and C by different ports do you mean different pins ?
    Can all the outputs be on the same port, preferably sequential?
    ie RC0:4 OR RC3:7 or similar
    SWITZERLAND (french speaking)
    Default Addressing multiple PORTs using one Variable
    Yes, ports will be in a sequential order.
    I'll be using ports:
    • Seconds: PORTC.3
    • Minutes Units: PORTC.4
    • Minutes Thenths: PORTC.5
    • Hours Units: PORTC.6
    • Hours Tenths: PORTC.7
    16F690 has:
    PORTA.0..5
    PORTB.4..7
    PORTC.0..7
    Roger
    By changing pinsel var you can select different portc pins
    if you need the remaining portc pins then more code is needed
    ' PIC 16F690 @20MHz#CONFIG
        __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_HS_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    TRISC = %00000000
    DEFINE OSC 20
    pinsel  var byte
    pinsel   = 128 ;  64 FOR RC:6    32 FOR RC:5 ETC
    MAIN:
        PORTC        = PORTC  | pinsel
                nop
                nop
                nop
        PORTC = 0         ' have this syntax for tests only here
                nop
        GOTO MAIN
    have you tried to light a rgb led strip with a 690 @20mHz yet ?
    i have doubts that such a slow chip will do the deed
    That's why I proposed APA102 chips. Not strict on the clock frequency.
    Check this:
    Roger
    And here's the project's code for now.
    Roger
  1. Addressing ports via offset using lookup command
    Last Post: - 1st November 2013, 03:50
  2. How to drive 7 segment using multiple ports?
    By guess79 in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:43
  3. multiple ports ===> one symbol?
    By PICMAN in forum General
    Last Post: - 8th March 2005, 22:24
  4. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 16:46
  5. Reading multiple ports
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 20th May 2004, 17:22
