Addressing multiple PORTs using one Variable
Results 1 to 32 of 32
    Default Re: Addressing multiple PORTs using one Variable
    not really the results i expected, more doubt on proteus ?
    i only expected the period to change
    SWITZERLAND (french speaking)
    Default Addressing multiple PORTs using one Variable
    So Richard,
    What is the idea now, then?
    Is there any "clean" -meaning software- workaround?
    If not, I'll have to make five small independant circuits to each drive his own NeoPixel string, five circuits controlled by a sixth one
    BTW, here is how my circuit works with 1 single NeoPixel string.
    https://youtube.com/shorts/4fZk9KT4V1M
    ...still in office now.
    Roger
    Are you displaying the same "information" on all 5 strings or calculating the "content" for each string on the fly as you go about updating them?
    Reason I ask is that 5 strings times 28 LEDs times 3 bytes per LED equals 420 bytes and the 16F690 only has 256 bytes of RAM.
    It is (going to be) a four digits 7 "segments" (each segment is made up of four NeoPixels >> 4x7= 28 NeoPixels per string) wall clock.
    The fifth segment is made of 2 or 4 four (not decided yet) NeoPixels and will serve as seconds separator/indicator.
    Yes, each string will be uptated specifically, if I can say so.
    By now, it all fits in my 16F690 nicely because I address the strings only once at the time or 1x28x3 bytes in total.
    Roger
    Can all the outputs be on the same port, preferably sequential?
    As Henrik pointed, I'm somehow limited in the number of bytes I can use to address the NeoPixel strings.
    Because of the very narrow timings, I cannot use routines to address the strings repeatetely with GOTOs/FOR-NEXTs/GOSUBs and so on. For this reason, I have to write code to address 24 bits for one Pixel in a row and only here, I can repeat the routine with one of the previous mentionned commands. This to say there is not only a timing issue but it is also about code length or space in the PIC.
    Having this limitations in mind, I started my project addressing one string at the time and I've got plenty of time to display a minute based clock. Since all strings use the same common code and therefore the same variables, I can only differentiate them using different ports.
    So if you mean to have only one NeoPixel string made of (4 digits x 7 segments x 4 Pixels [or LEDs] x 3 bytes per Pixel) + (4 Pixels x 3 bytes per Pixel) = 348 bytes, I can't address them in an array, as far as I understand it.
    But what do you have in mind, please?
    Roger
    There is an easier protocol for addressable LEDs. The APA102 that is not strict on timing.
    https://learn.sparkfun.com/tutorials...okup-guide/all
  1. Addressing ports via offset using lookup command
    Last Post: - 1st November 2013, 03:50
  2. How to drive 7 segment using multiple ports?
    By guess79 in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:43
  3. multiple ports ===> one symbol?
    By PICMAN in forum General
    Last Post: - 8th March 2005, 22:24
  4. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 16:46
  5. Reading multiple ports
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 20th May 2004, 17:22
