Trouble reading GPS from "NEO-6" module
Results 1 to 15 of 15
    Default Trouble reading GPS from "NEO-6" module
    Hello.
    I'm trying to read time from the GPS module "Neo-6"
    I asked AI to generate the code and here it is (with hardware config and DEFINEs by me):
    ;----[16F886 Hardware Configuration]--------------------------------------------
    cfg1 = _INTRC_OSC_NOCLKOUT    ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg1&= _WDT_ON                ; WDT enabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOR_OFF               ; BOR disabled
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
    cfg1&= _LVP_OFF               ; RB3 pin has digital I/O, HV on MCLR must be used for programming
    cfg1&= _DEBUG_OFF             ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins
      __CONFIG _CONFIG1, cfg1
    cfg2 = _BOR40V                ; Brown-out Reset set to 4.0V
    cfg2&= _WRT_OFF               ; Write protection off
      __CONFIG _CONFIG2, cfg2
    TRISA=%00000001  'SET A TO OUTPUT   1=input
    TRISC=%00001000   'set C3 for gps
    TRISB=%00011000   'set PortB to output
    ANSELH=%00000000   ' ADC OFF B
    ANSEL=%000000000 'configure PortA as digital except first 2
    ADCON1=%10000000  'adc justify
    OSCCON=%01110101  'SET FREQUENCY TO 8MHZ
    WPUB=%00000000    'turn off Pullups
    CM1CON0=0         'DISABLE COMPARATORS
    CM2CON0=0         'SAME HERE
    'CCP1CON=%01000000 ' configure pwm
    'PSTRCON=%00010110 'disable C pwm
    DEFINE OSC 8
    DEFINE ADC_BITS 12
    DEFINE ADC_CLOCK 5
    DEFINE ADC_SAMPLEUS 5
    'aska:
    serout2 portc.5,84,[" test-"," ",10,13]
    'pause 100
    'goto aska
    gps_data VAR BYTE[80]  ' Buffer to store GPS data
    gps_char VAR BYTE      ' Character received from GPS
    time_data VAR BYTE[6]  ' Array to store the extracted time
    i VAR BYTE             ' Loop variable
    start_found VAR BIT    ' Flag to indicate start of time data
    ' Define the serial pins
    GPS_RX var PORTC.2     ' RX pin for GPS (Adjust according to your setup)
    GPS_TX var PORTC.5     ' TX pin for GPS (Adjust according to your setup)
    ' Initialize variables
    start_found = 0
    i = 0
        ' Wait for data from GPS
        SERIN2 GPS_RX, 84, [gps_char]  ' 9600 baud rate with N, 8, 1 settings (84 represents the baud rate)
        serout2 GPS_TX, 84, [gps_char,","] 'also added by me for debugging
        ' Store data in buffer
        gps_data[i] = gps_char
        i = i + 1
        ' Check if we have a complete line of data
        IF gps_char = 10 THEN
            ' Look for the $GPRMC sentence
            IF (gps_data[1] = "G") AND (gps_data[2] = "P") AND (gps_data[3] = "R") AND (gps_data[4] = "M") AND (gps_data[5] = "C") THEN
                ' Extract time from the sentence
                start_found = 1
                FOR i = 7 TO 12
                    time_data[i-7] = gps_data[i]
                NEXT i
            ' Reset buffer
            i = 0
        'SEROUT2 GPS_TX, 84, ["Waiting...",10,13]    'added by myself for testing purposes
        ' Display time data
        IF start_found = 1 THEN
            SEROUT2 GPS_TX, 84, ["Time: ", time_data[0], time_data[1], ":", time_data[2], time_data[3], ":", time_data[4], time_data[5], 13, 10]
            start_found = 0
        GOTO main
    It does not work, but I added this: serout2 GPS_TX, 84, [gps_char,","]
    and it outputs series of chars and digits, and these digits do change, here's sample
    ,G,M,1,1,.,4,,,,,,,,,5,,,,*,
    ,N,A,8,3,9,,,,,4,
    ,$,G,,,0,2,7,,,,,0,,,,,,,6,
    ,P,A,,,,,,,,,
    ,P,A,,,,,,,,,,G,M,1,9,.,4,,,,,,,,,5,,,,*,
    ,N,A,8,4,9,,,,,4,
    ,$,G,,,2,0,7,,,,,0,,,,,,,6,
    So what I'm doing wrong?
    I tried to set GPS port speed to 4800 - it outputs garbage then.
    Default Re: Trouble reading GPS from "NEO-6" module
    First I would try Hserin and Hserout ONLY, because Serin and Serout are software commands and are slower. Besides they do not have any buffer, so I am pretty sure you loose characters from the data stream of the GPS miodule.
    If the test passes then I would check the rest.
    Thanks.
    I never used hardware serial port
    according to the datasheet for 16F886, there are 4 pins dedicated to the MSSP moduie
    RA5 - SS
    RC3- SCK/SCL
    RC4- SDI/SDA
    RC5 - SDO
    Which one should I use for serial GPS, as these seem to be for SPI/I2C ?
    None of these.
    We are talking about USART and not MSSP.
    The pins of interest are RC7 as Usart Rx pin and RC6 as Usart Tx pin.
    You have once to set the appropriate registers at the top of your program and start enjoy the speed and reliability of the serial port.
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h				'9600 baud rate, BRGH=1 @8MHz clock
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    DEFINE HSER_CLROERR 1
    I think that settings are incorrect, because
    aska:
    hserout ["Init:",10,13]
    pause 200
    goto aska
    Outputs something not correct, like question marks.
    these might need tuning?
    The output is TTL logic. Meaning you have to use a RS-232 driver to use it with PC. Either a transistor or a MAX232 type chip.
  1. Replies: 17
    Last Post: - 13th July 2020, 16:20
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. sending string to module GSM with character ""
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2010, 03:26
  5. 16F88 - AD converter module always "ON"
    Last Post: - 18th September 2006, 13:11
