Dimmer
Results 1 to 40 of 68
Thread: Dimmer
    Hi, I tried the following first:
    INTEDG  VAR OPTION_REG.6
    ACDetect:
        if triacdelay != 8000 then triac = 0
        if triacdelay > 0 then
            if triacdelay=8000 then
                triac=1 ' Activate TRIAC
                maxdelay=8000-triacdelay
                pauseus maxdelay
                triac=1
            triac=0
        INTEDG = !INTEDG
    @ INT_RETURN
    RESULT: The bulb attached to the output did not responded to the change in triac delay value, it just kept glowing at the same intensity.
    Then I experimented a little and came up with the following:
    while 1
    pause 3000
    high buz: pause 500 : low buz
    triacdelay=8000     : pause 15000 :high buz: pause 50 : low buz
    triacdelay=7998     : pause 15000 :high buz: pause 50 : low buz
    triacdelay=7950     : pause 15000 :high buz: pause 50 : low buz
    triacdelay=7900     : pause 15000 :high buz: pause 50 : low buz
    triacdelay=7850     : pause 15000 :high buz: pause 500 : low buz
    triacdelay=0        : pause 12000
    wend
    ACDetect:
    ;    if triacdelay != 8000 then triac = 0
                pauseus maxdelay
                    triac=1
                    pauseus 50
                    triac=0
            triac=0
        INTEDG = !INTEDG
    @ INT_RETURN
    RESULT: The bulb responded to the changing value of triac delay, at value of 8000 it goes full bright which is normal BUT when at first lower value than 8000, it dims quiet a lot. I want it to dim a only a little at first step. I even tried 7998 after 8000 but no luck i.e. 2 uS delay.
    You're right, I had the resistors wrong.
    Making the change brought it up to 4.6V.
    But, having the zeners in there adds about 40uS to the zero-cross signal.
    It takes 35uS without the zeners, and 75uS with them.
    Add in the interrupt latency for PBP type interrupts, time to do math in the handler, the minimum pauseus of 24us, and taking into account that a half cycle of 60hz is 8,333uS ... I'm sure the first step was quite a bit dimmer.
    But the biggest problem is delaying inside the interrupt handler.
    When 90% of the time is spent in the handler, the pause 10000 in the main loop takes almost a minute.
    So here's my next attempt.
    It uses Timer1 for the delays, so the main program can keep running in the foreground.
    The handlers have been changed to ASM type to minimize latencies.
    And the math is done in a separate subroutine that only runs once when you change the brightness, instead of having to do the math on every zero-cross.
    It should be pretty close to the MAX/MIN dimming, but you may need to adjust the MaxBright/MinBright constants a little.
    If you adjust them too far, it will start flashing.
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    Include "modedefs.bas"
    @ __Config _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN & _CP & _CPD
    MaxBright                   CON 8250    ; maximum brightness
    MinBright                   CON 200     ; minimum dimming
    Brightness                  var word
    TriacDelay                  var Word
    AlwaysON                    var BIT
    AlwaysOFF                   var BIT
    OffPeriod                   var BIT     ; used by timer1 periods
    Triac	var	PortA.1 ' Output to TRIAC gate
    ACLine	var	PortA.2 ' Input for the FullWave rectify AC line
    Buz		var PortC.2
    TMR1ON  VAR T1CON.0
    TMR1IF  VAR PIR1.0
    Timer1  VAR WORD EXT
    @Timer1 = TMR1L
    TRISA = %001100
    TRISC = 0
    CMCON = 7
    ANSEL = 0
    PORTA=0
    PORTC=0
            INT_Handler    INT_INT,    _ACDetect,   ASM,  yes
            INT_Handler   TMR1_INT,   _T1Handler,   ASM,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    @   INT_ENABLE  TMR1_INT     ; enable Timer1 interrupts
    Triac=0            ' disable Triac Gate
    brightness=0       ' Set delay to minimum
    gosub SetDelay
    while 1
        pause 3000
        brightness=MaxBright   : gosub SetDelay : pause 10000 :high buz: pause 50 : low buz
        brightness=MaxBright-2 : gosub SetDelay : pause 10000 :high buz: pause 50 : low buz
        brightness=4500        : gosub SetDelay : pause 10000 :high buz: pause 50 : low buz
        brightness=4000        : gosub SetDelay : pause 10000 :high buz: pause 50 : low buz
        brightness=3500        : gosub SetDelay : pause 10000 :high buz: pause 50 : low buz
        brightness=MinBright   : gosub SetDelay : pause 10000 :high buz: pause 50 : low buz
        brightness=0           : gosub SetDelay : pause 7000
    wend
    SetDelay:
        Brightness = Brightness min MaxBright                    ; limit maximum brightness
        AlwaysON  = !(Brightness != MaxBright)                   ; MaxBright is always ON
        AlwaysOFF = !(Brightness != 0)                           ; 0 is always OFF
        if !AlwaysOFF then Brightness = Brightness max MinBright ; limit minimum dimming
        triacdelay = -(MaxBright - Brightness)                   ; calc delay time
    T1Handler:
        if OffPeriod then            ; triac delay finished
            OffPeriod = 0
            triac=1                  ; turn on triac
            Timer1 = -50             ; load timer for 50uS
            triac = 0                ; turn off triac after 50uS
            TMR1ON = 0
    @ INT_RETURN
    ACDetect:
        if AlwaysON then
            if AlwaysOFF then
                triac = 0
                Timer1 = triacdelay  ; load delay into timer
                TMR1IF = 0           ; clear the interrupt flag
                TMR1ON = 1           ; start the timer
                OffPeriod = 1        ; tell T1Handler this is the main delay
        INTEDG = !INTEDG             ; toggle INTEDG to get both edges
    @ INT_RETURN
    Hope that works better.
    Thanks Darrel, I am on 50Hz, do I need to change any value in the code for that??
    There's another reason for the first step being much dimmer.
    Half a cycle of 50hz, is 10,000uS.
    So take MaxBright up to 9900.
  1. PICDIM Lamp Dimmer for the PIC12C508 - PICREF-4
    By charudatt in forum General
    Last Post: - 2nd September 2015, 07:14
  2. Dimmer switch
    By iugmoh in forum Off Topic
    Last Post: - 20th March 2009, 16:02
  3. Ideas on ir-code for dimmer
    By tirithen in forum mel PIC BASIC Pro
    Last Post: - 13th February 2009, 23:22
  4. 50hz sync for light dimmer
    By tirithen in forum General
    Last Post: - 6th September 2008, 19:29
  5. Dimmer Circuit
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 14:37
