Trouble reading GPS from "NEO-6" module
Results 1 to 15 of 15
    Default Re: Trouble reading GPS from "NEO-6" module
    I connected it directly to the PC via USB<>TTL serial adapter and with own software, u-center, it works fine - locks satellites, displays position, displays time.
    As I understand, I need to care for this line only:
    $GNZDA,202437.000,21,07,2024,,*48
    So I believe that issues are related with maybe voltage levels, I'll try to add some resistor dividers tomorrow and will check again.
    Fixed!
    Issue was with AI error - it suggested GPRMC as sequence to wait, but in real life it is GNRMC.
    Fixed it and everything works fine, even with software serial.
  1. Replies: 17
    Last Post: - 13th July 2020, 16:20
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. sending string to module GSM with character ""
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2010, 03:26
  5. 16F88 - AD converter module always "ON"
    Last Post: - 18th September 2006, 13:11
