PAUSE and ASM interruots
+ Reply to Thread
Results 1 to 6 of 6
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default PAUSE and ASM interruots
    I need some clarification about the behaviour of the PAUSE instruction (OR PAUSEUS) when an ASM interrupt occurs.
    First, will the interrupt be taken into account or ignored ?
    If taken into account will it immediatly terminate the PAUSE instruction or will it delay the execution of the remaining time of PAUSE until the ASM interrupt code is executed ?
    Thank you for your help.
    MikeBZH
    Default Re: PAUSE and ASM interruots
    Hello, Brittany
    an asm not masked interrupt will immediatly jump to ( generally ) location 4 of the program ... whatever the program is doing !
    that done ... a "classic" interrupt stubb will jump back to the remaining time of the PAUSE ( or Pauseus ). So no Delay guaranteed for the PAUSE statement ...
    BUT some tweaking can keep the PAUSE Length ( if possible ) : you have to substract the interrupt duration from the PAUSE PBP used internal counters ...
    Flankly ... your question needs to much better explain the context ... as it's not " crystal clear " !
    May 2009
    Hi Alain,
    Thank you for your answer which is perfectly clear.
    About the context :
    I have a permanent repetitive loop which successively calls several subs, always in the same order. This loop, wrotten in PBP, is periodically interruoted by an ASM program, There is no relation between the loop and the interrupt frequencies. Loop : about 2.5 kHz, interrupt : about 60 kHz.
    I want to slow down this loop so the simplest way would be to add some PAUSE inside. So my question was: "What occurs if an interrupt comes when a PAUSE is being executed".
    The loop duration is not critical at all, so the behaviour you describe should be appropriate.
    MikeBZH
    Pause is a PicBasic command.
    This command can be interrupted just fine with an ASM interrupt. But you have to be careful to save and restore critical registers during the ISR execution.
    The problem is evident in PicBasic On Interrupt system, because the Basic Interrupt will be executed after Pause has finish.
    Jun 2025
    Can I ask something related to this? Or should I start my own thread?
    Sure you can.
  1. Replies: 6
    Last Post: - 28th October 2014, 06:08
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 04:32
  3. Pause
    By blue in forum General
    Last Post: - 29th December 2005, 14:24
  4. Pause for 0.055msec??
    By Koraki in forum mel PIC BASIC Pro
    Last Post: - 27th August 2005, 15:11
  5. pause 0.5
    By detail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 11:32
Members who have read this thread : 9
