Reusing PGC & PGD pins
Results 1 to 21 of 21
Threaded View
  1. #12
    Default Re: Reusing PGC & PGD pins
    If you think that through the opto you can transfer the High and also the Low state of the 74HC14 then be sure it won't happen. When opto is ON, it will transfer the High state only. The Low state of the HC14 output cannot pass because collector of opto is reverse biased. You need then a pull down on the emmitter of the opto, which will have loading effect on the ICSP programmer.
    Best and simpler is to use a simple and cheap resistor to isolate the 74HC14.
  1. MCU with ICSP instead of PGD/PGC
    By Sabahan in forum PBP3
    Last Post: - 15th June 2020, 17:58
  2. 16F690 VREF PGC question
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2014, 17:14
  3. PGC (ICSPCLK) Conflicts with Vref ?
    Last Post: - 6th August 2012, 05:57
  4. number of PIC pins & 7-seg display
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 10:00
  5. PIC - 8 Pins - 6 Output Pins ?
    By DanPBP in forum Off Topic
    Last Post: - 22nd October 2007, 01:23
