Long Timer
Results 1 to 13 of 13
Thread: Long Timer
    Feb 2005
    Essex, UK
    Default Long Timer
    I have searched through numerous threads for an hour or so, but there are so many topics relating to timers and it is a little confusing.
    I am using a PIC18F2550 which when when of the inputs on the PIC are triggered, a counter starts. This counter needs to be setable by a variable in the code from 5 seconds to around 60mins.
    Once the timer has been triggered, if the same input or another for that matter on another two ports was triggered, it would stop the counter and go back to the beginning again. A kind of 'timer abort facility.
    Can any one pint me in the right direction?
    I've tried the pause command, but that only workks 65536 (65seconds)
    Many thanks.
    Feb 2005
    Essex, UK
    OK, i have have done a bit more digging and come up with this:
    Red     VAR PORTB.1
    Seconds     var byte ' 0-59
    Minutes     var byte ' 0-5
    Minutedelay var byte
    Minutedelay = 2
    counter = 0
    For Minutes = 0 to Minutedelay
        Gosub Delaymin
        If Minutes = Minutedelay - 1 then gosub flash
    Next Minutes
    Delaymin:
        For Seconds=0 to 59
        Pause 1000
        Toggle Red ' flashing light for reference
        Next Seconds
    Flash:
        For loop = 1 to 5
            red = 1
            pause 125
            red = 0
            pause 250
            red = 1
            pause 125
            red = 0
            pause 250
        Next loop
    I have had to put the
    in as it would not stop at the MinuteDelay variable. ie if i wanted it to stop at 2 minutes, it would stop at 3, if i wanted to stop at 3, it would stop at 4 etc etc.
    Is there any other way to tidy up this routine?
    Also, this routine is activated by, for argument sake, PORTC.0 going high. How would i place the abort code in. ie if the same button (PORTC.0) goes high during this routine, it stops the counting and jumps back to the main code awaiting an input instruction.
    I have a CASE SELECT routine which selects different routines, depending on which button is pressed. This is just one of the routines.
    Many thanks,
    ccsparky's Avatar
    ccsparky Guest
    I believe this is the same thing you are doing.
    MinuteDelay = 2
    For Minutes = 1 to MinuteDelay
    For Seconds = 1 to 60
    if PORTC.0 = 1 Then goto main code
    Pause(1000)
    Next Seconds
    Next Minutes
    For loop = 1 to 10
    red = 1
    pause(125)
    red = 0
    pause(250)
    Next loop
    Goto Main Code
    PORTC.0 will have to be held high for one second so that it can be picked up (will not be seen during a pause)
    Changed your loop from "1 to 5" to "1 to 10" since you were flashing red on and off twice in each loop.
    Your use of "If Minutes = Minutedelay - 1 then gosub flash" could have been
    "If Minutes = Minutedelay then gosub flash" if
    "For Minutes = 0 to Minutedelay" had been "For Minutes = 1 to Minutedelay"
    Since you are using PORTC.0 to send to and escape from the timer, make sure it is low when you return to main code or you'll just be sent right back to your timer or back to your main code if you are trying to activate the timer.
    I'm not sure if this is proper to do and maybe someone will explain if it is not but, if you have a PIC reset switch simply pressing it at anytime would abort the timer by means of resetting your PIC. You could then omit the
    "if PORTC.0 = 1 Then goto main code" in both places.
    William
    Feb 2005
    Essex, UK
    William, thanks very much for your reply.
    Your right about the abort routine. I wonder if there is another was to stop the effect where if the button is held down for the ABORT phase, when it jumps back to the main code, it will still be HIGH and thus start the delay routine again.
    With this you'll need to be quick off of the button to stop this from happening.
    Any other thoughts?
    ccsparky's Avatar
    ccsparky Guest
    Default Long Timer
    Tissy,
    How about a button just for abort purposes? Say PORTC.1
    Or maybe a 3 second pause after seeing PORTC.0 high during abort, allowing 3 seconds to get off the button, i.e.
    If PORTC.0 = 1 then
    pause(3000)
    goto main code
    end if
    I am curious to see other solutions also!!!
    William
    Also after reading more of your orginal post and seeing that you need to time by seconds, would this be more of what you needed:
    Low PortB.1
    Red VAR PORTB.1
    MinuteDelay VAR BYTE
    SecondDelay VAR BYTE
    Main Code:
    MinuteDelay = 2 '1 To 60
    SecondDelay = 0 '1 To 60
    If PORTC.0 = 1 Then Goto Timer
    Goto Main Code
    Timer:
    If MinuteDelay > 0 then
    Pause(1000)
    Next Seconds
    Next Minutes
    EndIF
    If SecondDelay > 0 then
    For Seconds = 1 to SecondsDelay
    pause(1000)
    Next Seconds
    EndIF
    For loop = 1 to 10
    HIGH red
    pause(125)
    LOW Red
    pause(250)
    Next loop
    Goto Main Code
    Sep 2005
    Campbell, CA
    Another way that has no PAUSE statements, so has very quick
    response to all inputs.
    ; Assumes 20 Mhz Oscillator
    T0CON =$86
    LOOP:
    IF INTCON.2 = 1 THEN
    INTCON.2 = 0
    TMR0H = $69
    TMR0L = $7A
    GOSUB SecondsTimer
    EndIF
    'Run regular code here (check for inputs, timeouts, etc)
    GOTO LOOP
    SecondsTimer:
    Seconds = Seconds + 1
    IF Seconds >= 60 THEN
    Seconds = 0
    Minutes = Minutes + 1
    IF Minutes >=60 THEN
    Minutes = 0
    Hours = Hours + 1
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  2. Replies: 5
    Last Post: - 24th February 2009, 19:55
  3. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  4. long countdown timer, how to save power?
    Last Post: - 15th November 2008, 06:15
  5. Timer and long (hours) sleep period - how to?
    Last Post: - 8th January 2007, 08:32
