Sht4x
Results 1 to 3 of 3
Thread: Sht4x
    Default Re: Sht4x
    what have you tried ?
    i fumbled around a bit with a scd41 which has a similar modus operandi and managed to get it to work with i2cread/write commands eventually , trick was to send a dummy 0 write prior to the needed delay before the result was read back
    Sep 2009
    Default Re: Sht4x
    Got it working, stupid datasheet....
    Address is $88, not $44, as in datasheet.
    Found that using
    https://www.picbasic.co.uk/forum/sho...C-Ping-program
    Then is straight forward
    1. Read serial
    SHTAdr=$88
    SHTCmd=$89
    I2CREAD S_SDA1,S_SCL1,SHTAdr,SHTCmd,[SHTArray[0],SHTArray[1],SHTArray[2],SHTArray[3],SHTArray[4],SHTArray[5]]
    0-1 serial 1 word, 2 crc, 3-4 serial 2 word, 5 crc
    2.Start conversion
    SHTAdr=$88
    SHTCmd=$FD
    I2CWRITE S_SDA1,S_SCL1,SHTAdr,SHTCmd,SensorFailNoAck
    3. Read Temp and RH data after 20mS
    SHTAdr=$88
    I2CREAD S_SDA1,S_SCL1,SHTAdr,[SHTArray[0],SHTArray[1],SHTArray[2],SHTArray[3],SHTArray[4],SHTArray[5]]
    0-1 hold temp, 2 hold crc, 3-4 hold humidity, 5 hold crc.
    If I add SensorFailNoAck, then it trigers every time, not sure why... I'll use crc to check for correct communication.
    CRC8 routine:
    CalcCRC:
    crc=$ff
     for byteCtr = 0 to 1
        TmpB=CRCArray[byteCtr]
        crc  = crc ^ TmpB
        for  i = 0 to 7
            if crc.7=1 then
                crc = (crc << 1)
                crc =  crc ^ $31
                crc =crc << 1
        next i
     next byteCtr
    Need to check calculation from ticks to T[°C] and RH[%].
    And to try to understand heater... How and why to use it.
