Sht4x
Results 1 to 3 of 3
Thread: Sht4x
    Sep 2009
    Default Sht4x
    Does anyone have SHT40 example code?
    I'm trying for 2 days, and no progress. Is it posible with i2cwrite, i2cread command?
    Trying to do conversion and read data, all 0's. Trying to read serial no, al 0's.
    HW connection looks good.
    Default Re: Sht4x
    what have you tried ?
    i fumbled around a bit with a scd41 which has a similar modus operandi and managed to get it to work with i2cread/write commands eventually , trick was to send a dummy 0 write prior to the needed delay before the result was read back
    Sep 2009
    Default Re: Sht4x
    Got it working, stupid datasheet....
    Address is $88, not $44, as in datasheet.
    Found that using
    https://www.picbasic.co.uk/forum/sho...C-Ping-program
    Then is straight forward
    1. Read serial
    SHTAdr=$88
    SHTCmd=$89
    I2CREAD S_SDA1,S_SCL1,SHTAdr,SHTCmd,[SHTArray[0],SHTArray[1],SHTArray[2],SHTArray[3],SHTArray[4],SHTArray[5]]
    0-1 serial 1 word, 2 crc, 3-4 serial 2 word, 5 crc
    2.Start conversion
    SHTAdr=$88
    SHTCmd=$FD
    I2CWRITE S_SDA1,S_SCL1,SHTAdr,SHTCmd,SensorFailNoAck
    3. Read Temp and RH data after 20mS
    SHTAdr=$88
    I2CREAD S_SDA1,S_SCL1,SHTAdr,[SHTArray[0],SHTArray[1],SHTArray[2],SHTArray[3],SHTArray[4],SHTArray[5]]
    0-1 hold temp, 2 hold crc, 3-4 hold humidity, 5 hold crc.
    If I add SensorFailNoAck, then it trigers every time, not sure why... I'll use crc to check for correct communication.
    CRC8 routine:
    CalcCRC:
    crc=$ff
     for byteCtr = 0 to 1
        TmpB=CRCArray[byteCtr]
        crc  = crc ^ TmpB
        for  i = 0 to 7
            if crc.7=1 then
                crc = (crc << 1)
                crc =  crc ^ $31
                crc =crc << 1
        next i
     next byteCtr
    Need to check calculation from ticks to T[°C] and RH[%].
    And to try to understand heater... How and why to use it.
