REVIEW: Vevor SDS1104 4 channel scope
Results 1 to 9 of 9
    Default Re: Vevor SDS1104 4 channel scope
    Wish you to enjoy your new toy!
    Regarding the modes and trigger it is necessary to read the manual. Every scope may have its own quirks.
    Nice buy, at a nice price.
    The fast rotation of the encoder may produce that spike like pulses because of capacitance on the lines an high pull up resistors.
    If you expect the signal to swing between 0 and +5V then set the trigger level to somewhere around 2.5V.
    As with input coupling the trigger coupling can usually be set to either AC or DC. Perhaps you have it set to AC and that's why the trigger level marker does not show on the right hand side of the screen.
    SINGLE waits for the trigger condition to be met, does an acquisition, displays it on the screen and stops. You have to re-arm the trigger.
    NORMAL waits for the trigger condition to be met, does an acquisition, displays on the screen, re-arms the trigger and goes back to waiting.
    AUTO is like NORMAL but if the trigger condition is not met within a certain time it does the acquisition anyway, re-arms the trigger and starts again.
    You should have some sort of indicator, either as a LED or a screen annunciator telling you if the scope is "trigged" (as with a repetitive waveform like PWM output) or "waiting" (as with something like a monitoring a button press).
    I have no experiece with your particular scope and have not looked at the manual but I would highly recommend reading it as even these $200-$400 scopes comes with an enormous amount of functionality. It's just incredible what you can get for less than brand name multimeter costs these days.
    would your mains power be at 60Hz ?
    hint 16.667mS...
    Yes it is (Canada, ~110VAC)
    ... the A B debounce looks very uneven between rising and falling edges. the unequal phase shifts so introduced will make R.E data interpretation interesting, especially at varying rotational speeds
    Yeah, I noticed the uneven edge times when I was doing my mechanical testing.
    Off the top of my head, I was planning on waiting for a first signal and watch for 2nd signal, then reset loop if no more signals. I haven't done any coding on it yet, but I was planning on keeping it very straight-forward.
  1. Looking for O-scope suggestions / reviews
    By Byte_Butcher in forum Off Topic
    Last Post: - 17th June 2010, 00:24
  2. Amicus 18 Review
    By lester in forum General
    Last Post: - 10th June 2010, 07:58
  3. Code Review?
    Last Post: - 29th May 2005, 13:48
