CircuitLab simulation
Results 1 to 13 of 13
    Default Re: CircuitLab simulation
    Simulating any part is impossible.
    Either you should choose a similar one (search the included lib or other people's lib) or make your own library. There are a few ways but I never tried really do my own. Though there are directions on many sites and forums.
    Bombay, India
    If you can accomodate some simulation inaccuracies, I suggest you try this circuit simulator. https://falstad.com/circuit/ Extremely frugal on resources.
    This is also downloadable as an offline circuit simulator.exe on the same site. To my knowledge, this is not accurate like LTspice or others, but gives a nice visual representation of the working circuit.
    I suggest this as an option with a very low learning curve.
    If you can accomodate some simulation inaccuracies, I suggest you try this circuit simulator. ...
    Thanks, I'll keep that one in mind if I ever try to simulate a circuit again.
    I had tried using that PWM board (FR120N, LR7843, D4184), but it the COB LED wouldn't completely turn off and I was stuck with flicker. I had tried ILD2 and LTV-825 opto-couplers, but I was serious trouble balancing the circuit (I can't remember the exact problems, but I couldn't get it to work as desired - full OFF/ON, 300mA range for COB LED, etc).
    I ended up with a IRFZ44N MOSFET driven by PWM from a PIC, with 1K on the gate; looks bullet-proof, low cost, minimal parts and super simple. Best part, it is driven from a PIC, so it's a snap reproducing the same lighting on the 2nd enclosure. These FETs can take insane voltages/amps (I'm only working with logic circuits).
    Small victory.
    Not at the same time though. You have to watch the SOA curve and then you will realize that it is not so impressive as the numbers advertised by the manufacturer...
  1. Simulation newbie, any pointers?
    By dsicon in forum PBP3
    Last Post: - 21st July 2015, 20:47
  2. PBP Simulation
    By andybarrett1 in forum General
    Last Post: - 19th March 2015, 10:01
  3. Proteus Simulation
    By Lectro in forum Forum Requests
    Last Post: - 26th August 2007, 23:35
  4. pulse simulation
    By nicolasronan in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:55
  5. Simulation
    By moby in forum General
    Last Post: - 21st January 2005, 18:16
