How to measure how long I pressed a button ?
Results 1 to 19 of 19
    Default Re: How to measure how long I pressed a button ?
    forget Proteus.
    Also I think Henrik forgot to add the label Exit: just before the Serout command.
    No, I did not forget to add a label.
    EXIT is a keyword used to break out of the current loop.
    AI, simulation, virtualization.... What happened to the good old breadboard?
    Do I really need to spin this up on my dev board here or can you do some troubleshooting on your own and not just say "it's not working". You did include the same setupcode used before didn't you?
    Dec 2008
    Ploiesti, ROMANIA
    It works ! Finally, the first program that shows me the duration. BUT .... the correct identification of the pressed button does not work ! I pressed ONLY button 0 : short or long ...It doesn't matter which button I press: if I press it briefly it indicates button 0, if I press it long it indicates button 5. Why?
    Anyway thanks for pointing into a good direction !
    Solved !
    the chances of AI finding well written pbp code to plagiarize from are slim at best.
    afaics AI can only write code if it can plagiarize it from somewhere, the code only works if the stolen code exactly matched your circumstances.
    its quite amazing that this plagiarism is tolerated just because a machine is stealing it. open source etc. does not mean you can copy it and pass it off as your own original work.
    breadboard , the manual and a data sheet is at least an honest and rewarding learning experience
    henriks work as it needs to be
    cfg =  _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_ON
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_ON
    cfg&= _BODEN_ON
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
      __CONFIG cfg
        CMCON    = 7
        TRISIO   = 111001
        INTCON   = $C0
        PIE1.0   = 1
        ANSEL    = 110001
        ADCON0 = 000001
    Long_Press CON 5000
    Short_Press con 100
    cnt VAR WORD
    b_level VAR BYTE
    but     VAR BYTE
    DataW VAR WORD
        GOSUB ReadButton
        IF but > 0 THEN
            cnt = 0
            WHILE but > 0
               cnt = cnt + 10
               if cnt > Long_Press THEN EXIT
               PAUSE 10
               GOSUB ReadButton
            WEND
            SEROUT GPIO.2, 2, ["You pressed button ", #b_level, " for ", #cnt, "ms", 13, 10]
    Goto Main
    ReadButton:
        ADCON0.1 = 1
        While ADCON0.1 = 1 : Wend
        DataW.HighByte = ADRESH
        DataW.LowByte = ADRESL
        but = 0
        if DataW < 805 then
                but=1
                if DataW > 50  AND DataW < 160 THEN b_level = 1
                if DataW > 180 AND DataW < 270 THEN b_level = 2
                if DataW > 290 AND DataW < 380 THEN b_level = 3
                if DataW > 400 AND DataW < 520 THEN b_level = 4
                if DataW > 540 AND DataW < 650 THEN b_level = 5
                if DataW > 690 AND DataW < 800 THEN b_level = 6
    a bit fancier
    #CONFIGcfg =  _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_ON
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_ON
    cfg&= _BODEN_ON
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
      __CONFIG cfg
        DEFINE INTHAND _TICK
        DEFINE DEBUG_REG GPIO
        DEFINE DEBUG_BIT 2
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        CMCON    = 7
        TRISIO   = 111001
        INTCON   = $C0
        PIE1.0   = 1
        ANSEL    = 110001
    CLEAR
    ' Constante
    TimerReload   CON   61637     ;3.906mS
    ' Variabile
    W_TEMP        VAR BYTE BANK0
    STATUS_TEMP   VAR BYTE BANK0
    MILLIES       var word BANK0
    b_level       var byte
    b_state       var byte
    NOW           var word
    LEDT          var word
    buttont       var word
    duration      var word
    DataW         var word
    GPIO.2 = 0
    ADCON0 = 000001
    T1CON = 000001 'Prescaler 1:1,Timer1  ON
        PIE1.0 = 0
        NOW = MILLIES    ;in 3.906mS ticks
        PIE1.0 = 1
        IF NOW - LEDT > 250 THEN    ;1 sec
            LEDT = NOW
            TOGGLE GPIO.1
        ADCON0.1 = 1
        if DataW < 805 then
          if  b_state == 0 then
                b_state  = 1
                buttont  = now
                DEBUG "button ",#b_level, 13, 10
          if   b_state then
    '           duration = (now - buttont)<<2
               duration = now - buttont
               buttont = duration.lowbyte */1000
               b_state  = 0
               DEBUG "Pressed button ",#b_level," for : ", #duration.highbyte,".",#buttont, " S", 13, 10
    '           DEBUG "Pressed button ",#b_level," for : ", #duration, "mS", 13, 10
               b_level = 0
    GOTO Main
    TICK:            ;isr
    asm
        MOVWF _W_TEMP ;copy W to temp register,could be in either bank
        SWAPF STATUS,W ;swap status to be saved into W
        BCF STATUS,RP0 ;change to bank 0 regardless of     current bank
        MOVWF _STATUS_TEMP
        MOVE?CT 0, T1CON, TMR1ON ; stop timer
        MOVLW LOW(_TimerReload) ; Add TimerReload
        ADDWF TMR1L,F
        BTFSC STATUS,C
        INCF TMR1H,F
        MOVLW HIGH(_TimerReload)
        ADDWF TMR1H,F
        MOVE?CT 1, T1CON, TMR1ON ; start timer
        MOVE?CT 0, PIR1, TMR1IF ; CLR timer FLAG
        INCF _MILLIES ,F
        BTFSC STATUS,Z
        INCF _MILLIES+1 ,F
        SWAPF _STATUS_TEMP,W;swap STATUS_TEMP register int    W, sets bank to original state
        MOVWF STATUS ;move W into STATUS register
        SWAPF _W_TEMP,F ;swap W_TEMP
        SWAPF _W_TEMP,W ;swap W_TEMP into W
        RETFIE
    endASM
    Last edited by richard; - 29th March 2024 at 11:04. Reason: note modified button 4 for my testing
    Dec 2008
    Ploiesti, ROMANIA
    Thank you very much !!! I can't wait to test it at the weekend !
    LE : I use PBP 2.5, so TimerReload CON 61637 = WARNING Line 10: 111001 Numeric overflow, value truncated.
    I use PBP 2.5, so
    i know nothing about ancient history
    and the number is word sized anyway
  1. TMR1 & Button - long delay (1 min) before starting
    Last Post: - 14th March 2017, 13:03
  2. Long / short press button...but reading ADC
    Last Post: - 10th July 2016, 08:37
  3. Replies: 5
    Last Post: - 26th February 2011, 05:51
  4. Replies: 1
    Last Post: - 14th October 2010, 18:33
  5. Button pressed time control
    By tanero in forum mel PIC BASIC Pro
    Last Post: - 15th August 2005, 15:17
