I2C Communication between PIC18F4550 and AS5600
Results 1 to 15 of 15
    Default Re: I2C Communication between PIC18F4550 and AS5600
    the data sheet address is a 7 bit address pbp uses 8 bit address
    what are ic2writes for ?
    they seem to be of no value that i can see
    you defined sda and scl why not use them ?
    more like
    start:
    I2CREAD SDA,SCL,$6C,$0E,[B0,B1]
    LCDOut $FE, 1, dec B1
    LCDOut $FE, $C0, dec B0
    goto start
    Mar 2024
    I thought that I need to send trigger first to AS5600 (Master mode), but I might be wrong.
    Can I ask you why did you use
    $6C in read command? Shouldn't it be $36?
    $36 is I2C address for AS5600
    the data sheet address $36 is a 7 bit address pbp uses an 8 bit address scheme
    You may well have to "configure" the device but for an i2c read transaction that is an unnecessary step
    $0F and $0E address for low and high bytes from encoder.
    both registers can be read in a single transaction as i indicated
    Mar 2024
    Does it mean that I can not communicate or I need to adjust the address?
    ok
    ok
    Thank you.
    Mar 2024
    I have used this one:
    and it works. Thank you very much for your help
    Jan 2010
    Glad to hear you got this working. I'll throw out a quick start I've been trying lately when interfacing to new chips for a basic frame work that gets me down the road quickly. I've been trying out OpenAi's Free chat bot.
    This is what I entered in for your pic and the AS5600.
    ChatBot Query: Write a PicBasic Pro program to read/write data from AS5600L-ASOM with the PIC18F4550 .
    Output: To interface the AS5600L-ASOM magnetic rotary position sensor with the PIC18F4550 microcontroller using PICBASIC PRO, you need to set up I2C communication. The AS5600L-ASOM uses the I2C protocol to communicate with the microcontroller.
    Here’s a sample program to read the angle data from the AS5600L-ASOM and write it to an output.
    PICBASIC PRO Code
    ' Define I2C pins
    DEFINE I2C_SDA PORTC.4
    DEFINE I2C_SCL PORTC.3
    ' AS5600L-ASOM I2C address (default 0x36 shifted for 7-bit addressing)
    AS5600_ADDR CON $36
    ' AS5600L-ASOM registers
    AS5600_ANGLE_H CON $0E
    AS5600_ANGLE_L CON $0F
    ' Variables
    angleH VAR BYTE
    angleL VAR BYTE
    angle VAR WORD
    ' Initialize I2C
    I2CINIT
    ' Main Program
        ' Read the high byte of the angle register
        I2CREAD AS5600_ADDR, AS5600_ANGLE_H, [angleH]
        PAUSE 10
        ' Read the low byte of the angle register
        I2CREAD AS5600_ADDR, AS5600_ANGLE_L, [angleL]
        PAUSE 10
        ' Combine high and low bytes to get the full angle value
        angle = angleH << 8
        angle = angle | angleL
        ' Convert angle to degrees (angle is 0-4095 representing 0-360 degrees)
        angle = (angle * 360) / 4096
        ' Add your code here to use the angle value (e.g., display on an LCD, send via serial, etc.)
        ' For example, send angle via UART
        SEROUT2 PORTC.6, 84, ["Angle: ", DEC angle, 13, 10]
        PAUSE 1000  ' Delay 1 second before next read
        GOTO main
    Explanation
    Define I2C Pins: Set the SDA and SCL pins for I2C communication.
    AS5600L-ASOM I2C Address: The I2C address for the AS5600L-ASOM is 0x36. Note that some libraries expect the 7-bit address shifted for 8-bit communication.
    AS5600L-ASOM Registers: Define the registers for reading the angle.
    Variables: Declare variables to store the high and low bytes of the angle, and the combined angle value.
    Initialize I2C: Use I2CINIT to initialize the I2C communication.
    Main Program Loop:
    Read the high byte and low byte of the angle register.
    Combine the high and low bytes to get the full 12-bit angle value.
    Convert the angle value to degrees.
    Use the angle value as needed (e.g., send via UART for display).
    Notes
    Ensure pull-up resistors (typically 4.7k ohms) are connected to the SDA and SCL lines.
    Adjust the SEROUT2 command for your specific UART configuration if needed.
    The angle value from the AS5600L-ASOM is 12 bits, representing a range of 0-4095, which maps to 0-360 degrees.
    This code provides a basic framework for interfacing the AS5600L-ASOM with a PIC18F4550 microcontroller using PICBASIC PRO. You can expand and modify it based on your specific requirements.
    It's not perfect but can get some project started quickly as a reference.
    Well, many times I tried to make ChatGPT understand that variable definition is special in PBP and different from other dialects of Basic.
    And it finally got it!!! Amazing... this thing is indeed learning!
    Of course needs more details on the prompt to make a useful program. Or at the end instead of detailed prompt, just write the program yourself
  1. Replies: 18
    Last Post: - 4th July 2017, 14:26
  2. PIC18F I2C Communication with Arduino
    By picmilan in forum mel PIC BASIC Pro
    Last Post: - 14th July 2016, 21:38
  3. Replies: 0
    Last Post: - 26th May 2012, 13:57
  4. EEprom and MCP9801 I2C communication problems
    By aajgss in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2011, 21:45
  5. Replies: 2
    Last Post: - 10th June 2005, 02:34
