Fuse Error
Results 1 to 3 of 3
Thread: Fuse Error
    eoasap's Avatar
    eoasap Guest
    Default Fuse Error
    IDE: using microcode studio 2.3.0 (shareware version)
    Programmer: K182A USB ICSP programmer (with MicroPro user interface)
    PIC18F452 DIP package
    OSC: 4mhz crystal
    i keep getting fuse errors when trying to program the chip and not sure if its a fault with the programmer (micropro), picbasic, or 'user' error .
    FUSE settings are made through micropro (is there a way to set ALL the fuse settings in picbasic?)
    all default fuse settings except oscillator type (to XT), watchdog timer disabled, and low voltage program disabled.
    I can't think of any other info i've left out or if anyone here uses a similar setup, but if you can help, please let me know.
    I'm also very interested in setting the fuses (other than oscillator) with picbasic but dont see it anywhere in the manual on how to do that.
    TIA!
    Glenn
    Everything is covered in the following link
    eoasap's Avatar
    eoasap Guest
    Thanks Steve! looking it up right now
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  2. Loop with two motor and 2 sensors
    Last Post: - 8th December 2008, 23:40
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
