JLCPCB ordering tip
Results 1 to 23 of 23
    Default JLCPCB ordering tip
    (Just a head's up to the next guy.)
    I thought that ordering in panels was cheaper than single PCBs. Turns out I was wrong; I suppose they spread out our single panels wherever they have empty slots in their production run.
    At least, that's the observation I made using a 6" x 9" (15cm x 20cm) layout I uploaded (I wanted to see the price difference between 2 layers and 4 layers). It might be different with small circuits, I didn't try it.
    Also, I get a "large panel" surcharge when I use panels of this dimension, even when choosing 2 x 2.
    20 PCBs, 2 layers:
    - single, $ 3.73 ea.
    - 2 x 2, $ 7.70 ea.
    20 PCBs, 4 layers:
    - single, $ 6.24 ea.
    - 2 x 2, $ 10.27 ea.
    100 PCBs, 2 layers:
    - single, $ 2.24
    - 2 x 2, $ 5.09
    100 PCBs, 4 layers:
    - single, $ 3.96
    - 2 x 2, $ 6.54
    Nothing fancy, just two 14-pin headers and a 28 pin smd PIC spread out across the surface.
    EDIT: I think I know where the savings from panels comes from, it's probably when you use their assembling service and you don't use basic parts (they're preloaded on the machine). A technician has to go to inventory and load reels of "extended parts" on the machine.
    Default Re: JLCPCB ordering tip
    I think the charge on a panel is for the whole panel.
    In your first example
    20 PCBs, 2 layers:
    - 2 x 2, $ 7.70 ea. <-- here I think is for the panel, the 4 pcbs, Not each one.
    Maybe I am wrong, have not tested right now.
    Those prices are for each individual circuit. I was careful not to use panel prices and mix apples with oranges. I wanted to get a better idea on batches of 100 instead of small prints.
    And I was testing the idea of a single motherboard in the background, instead of wires from MCP23017 to the PICs.
    I was checking prices on JLCPCB for a MCP23017 circuit, and I noticed something when I entered their part numbers.
    Did you know you can buy parts from other customers when JLCPCB doesn't have enough stock?
    Name:  JLCPCB marketplace.png
    I have to do some tests tomorrow (2:30 am here). I'm going to try using all parts at 0 inventory, and see if I get deals.
    But this might be an easy way for us peasants to get even better priced components.
    Regarding passives, like R's and C's, there are millions of brands and types available (but not on stock all the time).
    It gives me headache everytime I have to do an assembly by JLCPCB...
    But on the other hand, this option is nice. Can you order also from Mouser Digikey etc?
    ...But on the other hand, this option is nice. Can you order also from Mouser Digikey etc?
    Yup, you can pre-buy parts from suppliers by JLCPCB.
    Pre-order the required components in advance to ensure sufficient components are ready anytime.
    Place a PCBA order with confidence at any time when your design is ready.
    I just did a test with intentionally insufficient JLCPCB stock, but the prices were still twice as high, even for headers, resistors and capacitors.
    It "might" come in handy for more expensive ICs, I don't have a circuit ready yet with a PIC, but I'm not holding my breath.
  1. PROBLEMS ORDERING PICBASIC PRO mechanique.co.uk
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 27th September 2009, 19:11
  2. Tip: For Non working gLCD on EasyPic5 Board
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 18:07
  3. Codespace Saving Tip... Don't mix Words and Bytes
    Last Post: - 18th June 2004, 10:23
