Serial comms / Bootloader
Results 1 to 15 of 15
    -did you disable the handshaking?
    <font color="red">Yes</font>
    - What about if you use MicroCode Studio Serial Communicator instead?
    <font color="red">MicroCode Studio Serial Communicator works!!!</font>
    <font color="red">But with visual basic or hyperterminal it does not work?
    Any idea what is the difference between the 2?
    </font>
    -Is your MCLR pin is tied to VCC via resistor?
    In VB you'll need to disable the DTR line. Here's a usual COM port setting in VB
        '   Serial Communication Definition
            With MSComm1
                .CommPort = 1                 ' Using COM1
                .Settings = "9600,N,8,1"      ' 9600 bauds, no parity, 8 data bit,
                                              ' 1 stop bit
                .Handshaking = comNone        ' no handshaking
                .DTREnable = False            ' disable DTR line.. avoid PIC stuck if using
                                              ' bootloader circuitry
                .EOFEnable = False            ' disable EOF event
                .InputMode = comInputModeText ' Get Text from COM port
                .RThreshold = 1               ' amount of character to be receive prior to
                                              ' generate a CommEvent
                .InputLen = 0                 ' get the whole string
                .PortOpen = True              ' open COM port
                End With
    MCS don't use and disable the DTR line for you.. not Hyperterm (wich i stay far of)
    Steve - Before you confuse half the forum readers - that's not a MAX232 jpg...
    Yes it is! comming directly from the Maxim datasheet bellow...
    http://pdfserv.maxim-ic.com/en/ds/MAX220-MAX249.pdf
    there's some little character to read at the bottom of the picture ;-)
    From the Maxim datasheet:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=576&stc=1&d=1130688459 ">
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=577&stc=1&d=1130688459 ">
    From the Texas Instruments datasheet:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=578&stc=1&d=1130688459 ">
    The correct pic is in the datasheet you just posted, but what I'm trying to say is that the jpg you've put up a couple of posts above is not of a MAX232... a MAX232 does not have enable connections on it's inverters. I refer you to Figure 5 on Page 17.
    COOL!!
    DTREnable is working!!!!
    Thank you Steve!!!
  1. Serial Comms through TX/RX pair jumbled
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 22:04
  2. Simple Serial Comms.
    Last Post: - 23rd November 2007, 09:12
  3. Serial Comms with PIC micros
    By carlsnilsson in forum mel PIC BASIC Pro
    Last Post: - 21st September 2006, 02:00
  4. Replies: 2
    Last Post: - 23rd July 2006, 09:16
  5. BootLoader with USB to Serial Convertors
    By mike101video in forum General
    Last Post: - 10th January 2006, 17:48
