Serial comms / Bootloader
Results 1 to 15 of 15
    Thank you!
    Hi Steve
    Someone told me that the MAX232 has an internal 5K pull down.
    It would not be necessary to put a pull down resistor as you have described.
    Is this correct?
    If i refer to the Maxim datasheet...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=573&stc=1&d=1130593189 ">
    there's indeed a pull-down resistor... mmm for the TI one, i guess it's the same.
    mmm... Hyperterminal could be the cause...
    1. did you disable the handshaking?
    2. What about if you use MicroCode Studio Serial Communicator instead?
    3. Is your MCLR pin is tied to VCC via resistor?
    4. What about if you use the original solution (resistor instead of capacitor)?
    I bet on the Handshake idea now.
    -did you disable the handshaking?
    <font color="red">Yes</font>
    - What about if you use MicroCode Studio Serial Communicator instead?
    <font color="red">MicroCode Studio Serial Communicator works!!!</font>
    <font color="red">But with visual basic or hyperterminal it does not work?
    Any idea what is the difference between the 2?
    </font>
    -Is your MCLR pin is tied to VCC via resistor?
    In VB you'll need to disable the DTR line. Here's a usual COM port setting in VB
        '   Serial Communication Definition
            With MSComm1
                .CommPort = 1                 ' Using COM1
                .Settings = "9600,N,8,1"      ' 9600 bauds, no parity, 8 data bit,
                                              ' 1 stop bit
                .Handshaking = comNone        ' no handshaking
                .DTREnable = False            ' disable DTR line.. avoid PIC stuck if using
                                              ' bootloader circuitry
                .EOFEnable = False            ' disable EOF event
                .InputMode = comInputModeText ' Get Text from COM port
                .RThreshold = 1               ' amount of character to be receive prior to
                                              ' generate a CommEvent
                .InputLen = 0                 ' get the whole string
                .PortOpen = True              ' open COM port
                End With
    MCS don't use and disable the DTR line for you.. not Hyperterm (wich i stay far of)
    Steve - Before you confuse half the forum readers - that's not a MAX232 jpg...
  1. Serial Comms through TX/RX pair jumbled
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 22:04
  2. Simple Serial Comms.
    Last Post: - 23rd November 2007, 09:12
  3. Serial Comms with PIC micros
    By carlsnilsson in forum mel PIC BASIC Pro
    Last Post: - 21st September 2006, 02:00
  4. Replies: 2
    Last Post: - 23rd July 2006, 09:16
  5. BootLoader with USB to Serial Convertors
    By mike101video in forum General
    Last Post: - 10th January 2006, 17:48
