a simple probe... use another PIC.
Code:Start: While PICInput=1 : wend HIGH LED pause 2000 LOW LED goto Start
Hi Steve
Someone told me that the MAX232 has an internal 5K pull down.
It would not be necessary to put a pull down resistor as you have described.
Is this correct?
If i refer to the Maxim datasheet...
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=573&stc=1&d=1130593189 ">
there's indeed a pull-down resistor... mmm for the TI one, i guess it's the same.
mmm... Hyperterminal could be the cause...
- did you disable the handshaking?
- What about if you use MicroCode Studio Serial Communicator instead?
- Is your MCLR pin is tied to VCC via resistor?
- What about if you use the original solution (resistor instead of capacitor)?
I bet on the Handshake idea now.
-did you disable the handshaking?
<font color="red">Yes</font>
<font color="red">MicroCode Studio Serial Communicator works!!!</font>
<font color="red">But with visual basic or hyperterminal it does not work?
Any idea what is the difference between the 2?
</font>
-Is your MCLR pin is tied to VCC via resistor?
In VB you'll need to disable the DTR line. Here's a usual COM port setting in VB
MCS don't use and disable the DTR line for you.. not Hyperterm (wich i stay far of)Code:' Serial Communication Definition ' =============================== ' With MSComm1 .CommPort = 1 ' Using COM1 .Settings = "9600,N,8,1" ' 9600 bauds, no parity, 8 data bit, ' 1 stop bit ' .Handshaking = comNone ' no handshaking .DTREnable = False ' disable DTR line.. avoid PIC stuck if using ' bootloader circuitry ' .EOFEnable = False ' disable EOF event .InputMode = comInputModeText ' Get Text from COM port .RThreshold = 1 ' amount of character to be receive prior to ' generate a CommEvent ' .InputLen = 0 ' get the whole string .PortOpen = True ' open COM port End With
Hi, Steve
Have a look there : http://www.beyond-designs.com/PC_ports.htm#VBHexTerm
or :
http://www.synthmodules.com/other/VBHexTerm-Setup.exe
... nice !!!
