Latest PICs - how to program them?
Results 1 to 22 of 22
    Aug 2011
    Default Re: Latest PICs - how to program them?
    ... or if you really want the latest PICs then checkout Mecanique's Swordfish BASIC, but that only supports PIC18F family.
    I think this is also at stall...
    Aug 2011
    Not at all.
    Swordfish supports ALL the 18F family of devices, including the newer Q family... Q10, Q40, Q41, Q43, Q83, and Q84.
    Support for the Q20, Q24, and Q71 devices will be released shortly.
    Aug 2011
    Well some did and moved on to C compilers or Positron Basic compiler.
    Positron Basic has the same problem as PBP... no support for devices not included with MPASMX 5.87.
    That rules out a number of newer 18FxxQxx and 16F1xxxx parts.
    Interesting. Gonna look at SW. I've been itching to use the Qs.
    Not at all.
    How is SF with USB? I just got the latest HIDMaker. I'm wondering how we can use that code with SF.
    https://www.tracesystemsinc.com/blog...rocessors.html
    I suppose I could finally make the switch to C++ on the PIC side; I'm already doing that for the Windows side. The part that bugs me is losing all the utilities that have been developed by Darrell and others here. Is there as strong a community over with SF?
    EDIT: Holy crap! "ConvertTemp - Convert temperatures in any direction between Fahrenheit, Celsius and Kelvin. Written by Darrel Taylor."
    EDIT SOME MORE: Wow! "Supports all current 45 18F USB devices, including 18F2550, 18F4550, 18F2553, 18F4553, 18F2455, 18F4455, 18F2458, 18F4458, 18F2450, 18F4450,18F14K50, 18F13K50, 18F24K50, 18F25K50, 18F45K50, 18F24J50, 18F25J50, 18F26J50, 18F44J50, 18F45J50, 18F46J50, 18F65J50, 18F66J50, 18F67J50, 18F85J50, 18F86J50, 18F87J50, 18F26J53, 18F27J53, 18F46J53, 18F47J53, 18F66J55, 18F86J55, 18F65J94, 18F66J94, 18F67J94, 18F85J94, 18F86J94, 18F87J94, 18F95J94, 18F96J94, 18F97J94, 18F66J99, 18F86J99, 18F96J99"
    Aug 2011
    No idea about that one... not familiar with HIDMaker, but if it produces code for PBP I would think its output could be massaged to work with SF.
    All of the SF libraries are in source code so you can modify pretty much everything.
    Using interrupts in SF is not as straightforward as in PBP (especially using DT-INTS).
    Have a look here: https://www.sfcompiler.co.uk/phpBB3/...php?f=3&t=2210
    Aug 2011
    A lot of it really depends on what your ISR is doing.
    Just like PBP you can choose to save just the pic registers or also include the BASIC system library variables.
    SF has the additional complication due to the shared frame variables, a powerful feature which can reduce RAM usage a LOT.
    If saving the context is really complicated that's a good clue you should probably examine what your ISR is actually doing in the first place... most folks do WAY too much in the ISR.
    In most cases it's not nearly as complicated as it sounds, but the nice thing with SF is that you can easily control what gets saved without having to resort to editing asm libraries, etc., and can be done on an individual case-by-case basis.
  1. Me again :) -- latest PBP?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 10th February 2020, 22:06
  2. Program 3 PICs using one PICKIT 3. Possible?
    By BobEdge in forum General
    Last Post: - 3rd July 2015, 17:20
  3. Latest RTC
    By aloon15 in forum mel PIC BASIC Pro
    Last Post: - 20th September 2014, 23:47
  4. Latest devices not listed
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 24th February 2011, 20:32
  5. Latest RTC
    By Fred in forum mel PIC BASIC Pro
    Last Post: - 13th November 2008, 15:34
