MCP3301 A/D converter SPI reading
Results 1 to 15 of 15
    Default Re: MCP3301 A/D converter SPI reading
    the last bit will indicate either "+" or "-", right?
    if by last bit you mean the msb then yes
    not forgetting its a 13-bit binary two’s complement number
    SWITZERLAND (french speaking)
    Default MCP3301 A/D converter SPI reading
    ...and that means what exactly please?
    Roger
    Your ADC is differential one. So, that means it can convert positive and also negative (in relation to the two inputs + and -) voltages.
    If the + input is more positive than the - input of the converter then the output will be a plain 12 bit binary number.
    But if the - input is more positive than the + input, then as you can understand the result of the ADC should be negative. This is shown in binary with the most significant bit (MSB) of the value being 1. That is the sign bit.
    But the rest of the 12 bits follow a specific rule then. All bits are reversed and also -1.
    For example, 1 1111 1111 1111 means negative number and this number is the reverse of 1111 1111 1111 plus one, or just 1. So in total -1.
    Or, 1 0000 1111 0000 is also negative and the value is -3856
    Hope this clear a bit of the mud!
    More here https://www.cs.cornell.edu/~tomf/not.../twoscomp.html
    Thanks Ioannis and sorry for the late reply,
    So, if I would connect GND to the "-" input and measure i.e. a + signal from 0 to 5 Volts, I should have as 12 bits result, right?
    This is confusing to me. I get the positive and negative thing but I can't figure out how you come to this 3856 number?
    Roger
    to expand a 13 bit negative two's complement number to a 16 bit number bits 13,14 an 15 need to be set accordingly
    in general the "sign bit" needs to be extended to the new width
    so 1 0000 1111 0000 becomes 1111 0000 1111 0000 qed -3856
    Yes, Richard is correct. I forgot to mention you have to adjust the value to the byte, word or whatever width you have.
    So the sign is the left most bit but the rest should also be 1. Remember we reverse the bits to get the absolute value disregarding the left most, sign bit.
    Seems confusing at first, but has its logic.
    Thumbs up MCP3301 A/D converter SPI reading
    Got it now!
    Thanks a lot
    Roger
  1. Reading DS1620 (SPI Temperature) from 18F46k22 Micro at 16MHz
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 13th June 2015, 00:24
  2. Need to use SPI but I'm already using the SPI port
    Last Post: - 30th December 2012, 09:52
  3. SPI on a pic without hardware SPI?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 26th April 2006, 13:29
  4. Isolated A/D converter, SPI I/F
    By srob in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 07:18
  5. help D/A converter
    By matelda in forum mel PIC BASIC Pro
    Last Post: - 8th September 2004, 17:25
