Count Down Timers
Results 1 to 3 of 3
    Default Count Down Timers
    I would like some suggestions on what to use for a count down timer. There are actually two timers needed, one for counting down seconds and another for counting down minutes. The seconds one will have a maximum duration of 60 seconds and the minutes one will be 60 minutes. This is to simplify our powder coat painting baking oven operation.
    why not using RTC. Read actual time, then do the math according to your need... just need to poll the RTC register.
    OR use the AC line as time base then count secondes+minutes+hours.
    OR use the internal tick to generate 1 seconde time base then...
    OR a PAUSE loop then...
    It's all depend of what else your PIC will need.
    Feb 2004
    Germany
    Quote Originally Posted by CocaColaKid
    .... This is to simplify our powder coat painting baking oven operation.
    For this kind of application I would guess timing is not really critical, you certainly don't need an accuracy of a tenth of a second (or even a second)
    So a simple loop should do.
    regards
    Ralph
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Hardware timers
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2008, 03:26
  4. Reading Timers
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 27th August 2007, 09:19
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
