Behringer potentiometer
Results 1 to 11 of 11
    Default Re: Behringer potentiometer
    Audio mixers use them. Something about how the human ear works.
    Any audio volume control will use logarithmic curve. Any tone control and balance uses linear as far as I know.
    A mixer should also use log curve since it controls volume.
    I don't know.
    I bought a bunch of those Behringers thinking linear meant linear.
    Apparently I was wrong. Sometimes it means "nearly" linear.
    Is it a serious problem for your project? If yes, maybe you can calibrate it with software.
    It is. People expect engine rpm to rise with throttle input.
    I could, but I shouldn't have to. I'm waiting for a reply from bourns on an ordinary linear slide pot.
    I agree. Hope you resolve this.
    You inspired me to figure this out. My goal with this pot is to simulate the flaps lever in a Cessna 152 in MSFS 2020:
    I added a frame around the slide pot with an edge on top at both ends, and indentations on both sides.
    The skate just slides onto the shaft, with tiny "skiis" under to slide 1mm above the pot surface (the dust cover curls up as the shaft moves up and down, this causes friction under the skate if it's not elevated).
    The arms on both sides have a bump that fits just right in the indentations.
    This was made with PLA, but it'll most likely be ABS or PETG in final form. I'll just add a dab of lithium grease on both sides once I find out what lubricants I can safely add on those plastics.
    I'm happy cause this will permit me to use the 100 or so I bought from AliExpress, and I get EXACTLY the feel I wanted on the device. I get 4 detents, but can still stop anywhere in between just like in-game.
    (the action is super smooth, I have problems in the video cause I'm holding my phone, and the PCB slides on the paper so I have to push downwards with unusual effort)
  1. how to get an analog potentiometer to settle down?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2016, 19:01
  2. Potentiometer reading
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 9th January 2012, 01:19
  3. Using sound/audio as a potentiometer?
    By mekohler in forum Schematics
    Last Post: - 24th October 2007, 20:53
  4. Switch / Potentiometer
    By bearpawz in forum Off Topic
    Last Post: - 19th January 2007, 21:45
  5. Potentiometer with indexing.
    By muddy0409 in forum General
    Last Post: - 1st January 2006, 19:41
