Behringer potentiometer
Results 1 to 11 of 11
    Default Behringer potentiometer
    A neat slide dual 10K potentiometer on AliExpress.
    Name:  Behringer B10K pot.jpg
    If you thought the 2 pins on the far left were the wipers, you'd make the coolest short circuit that can fry lots of gizmos. The wipers are on the right; they don't have a pin lined up with them on the far left.
    Fortunately I tested each circuit as I was soldering them. Of course this pot was the last component I installed on the board. So now I have to scratch out some traces, and jump with wires.
    Teach me right. (heavy sigh)
    Default Re: Behringer potentiometer
    Heads up to the next guy that looks at these taper B 10K pots.
    They are not completely straight linear, they have a slight curve at the 25% and 75% curve.
    They are between the taper B3 and B4 on page 4:
    https://www.bourns.com/docs/Product-Datasheets/PTL.pdf
    These are NOT taper B1. They sure are smooth though.
    Why would one need such a curve?
    Audio mixers use them. Something about how the human ear works.
    Any audio volume control will use logarithmic curve. Any tone control and balance uses linear as far as I know.
    A mixer should also use log curve since it controls volume.
    I don't know.
    I bought a bunch of those Behringers thinking linear meant linear.
    Apparently I was wrong. Sometimes it means "nearly" linear.
  1. how to get an analog potentiometer to settle down?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2016, 19:01
  2. Potentiometer reading
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 9th January 2012, 01:19
  3. Using sound/audio as a potentiometer?
    By mekohler in forum Schematics
    Last Post: - 24th October 2007, 20:53
  4. Switch / Potentiometer
    By bearpawz in forum Off Topic
    Last Post: - 19th January 2007, 21:45
  5. Potentiometer with indexing.
    By muddy0409 in forum General
    Last Post: - 1st January 2006, 19:41
