3D printer, thread 2
Results 1 to 4 of 4
    Default 3D printer, thread 2
    Since this thread has been closed, and we can't seem to open it:
    https://www.picbasic.co.uk/forum/sho...826-3D-printer
    I finally got a Creality Ender 3 S1 Plus on Amazon.ca for $689 back in March 2023 (currently $552 from Creality):
    - Sprite Direct Drive Extruder,
    - Auto Bed Leveling, (more like auto-compensating, you have to manually twist the wheels),
    - CR Touch controller,
    - Upgraded Dual Z Axis,
    - Silent Board,
    - Heated bed,
    - PC sprint steel magnetic build plate,
    - Printing Size 300x300x300mm
    It doesn't have multiple colours, but I had to start somewhere.
    It has a flexible magnetic build plate. I really like this feature.
    I've since had 1 problem during the year: motherboard and controller board - probably from a lightening strike. Both replaced and it's now working fine.
    I've only done PLA so far, but plan on trying ABS as soon as I move to a new area with venting to outside.
    Speed, nothing to get excited about.
    Precision, good enough for me so far.
    Part removal, the spring steel plate seems to have a lot less problems when removing the finished piece than other bases.
    Overall, I'm happy with it, 7 / 10.
    FILAMENT: I've only bought Amazon and haven't had any problems. I don't use a dryer, and my current filment just sits installed on the printer. At most, I wrap opened filament rolls in a freezer ziplock bag.
    TIP: make sure to keep the loose filament firmly anchored into the roll when removed from the printer. You will not be happy if the filament coils start loosening over each other. Just google tangled PLA filament roll.
    Default Re: 3D printer, thread 2
    Software: FreeCad
    Slicer: Creality
    12V LED light strip
    Name:  LED light.jpg
    Mods on a 3018 mini-CNC (with LED lamp installed):
    Name:  Vevor mini-CNC b.jpg
    - 6 limit switches,
    - upper linked cable track,
    - 2 fixed cable tracks,
    - vacuum attachment,
    - panic button (top right),
    - control box,
    - PCB clamp fixtures.
    I still have to make a tool rack.
    Looks very nice machine.
    [I] Just google tangled PLA filament roll.
    I do not have a 3D Printer and never occured to me how you can ruin your overnight printing with such a stupid problem...
    Wow!
    Do you use that 3D printer as a CNC machine also?
    Nope.
    It works so I'm not messing with it.
  1. 3D printer
    By xapmanis in forum Off Topic
    Last Post: - 18th June 2018, 11:47
  2. Replies: 20
    Last Post: - 25th May 2012, 15:37
  3. Thermal printer
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 16:35
  4. PIC to Printer
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 00:22
